For sale: G2 chrome wheels, tyres have more than 90% tread, No gutter rash for 3 of the wheels only the rear left one have very minor scuff which is barely noticeable when it is on the car... asking for $1200 ono pm me if interested.
What's your location?
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
