sorry guys only just got internet access...
the small crack in the block that was repaired last time engine was freshened has opened up weeping coolant out. In the interests of my own and others safety i decided not to run the car. Looking back i probably should have grouted the block as the crack is below the bottom of the welsh plugs and grouting would have stopped it.
Its very strange as when the car was rolled back on Friday no coolant was leaking out of it. A little later i jacked the front of the car up in preparation for welding a lambda sensor bung at the base of the dump pipe and coolant started to drip from the rear of the engine. We stripped the engine on Friday night and tried to repair it but on Saturday morning started leaking again. Engine is now out and ill decide tomorrow if ill just grout it or replace the block with a fresh one.
Very disapointing for all involved with the car.
As u said paul, last thing u want to do is bin it down the track with coolant on the back wheels @ 150mph.
Safety first :unsure:
  • Replies 66
paul explained to me that the crack was repaired 5yrs ago...maybe from all of the strain the engine has undergone caused the crack to weep?
yeah have known about the crack for quite some time...has been pretty good up till now. Most 05U blocks will open up when subjected to this power level for a long period. All the bogged launches twisting and stressing the block would have done it no favours.
I grouted it this afternoon...no more weeping coolant. Was going to machine up another block but didn't want to crack a good one. Engine back in by the end of the week.
Sorry to hear about the bad news Paul, hope you get it all sorted this time mate.
In your experience, for block strength is it ok to grout as far as the welsch plugs and still use the engine for circuit work? Any coolant issues?
i would not recommend it. bottom of the welsch pluds as a maximum. but run extra piston to bore clearance.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
