So ive got my wideband controller working on the bench, time to hook it up to the car and get some data logging done.
The wideband controller has various inputs for speed, rpm etc... all from the ecu.
What I would like to know is, what is the best way to tap into the ecu to get the signal? Im fearing the only way I have is to cut and re solder the wire harness as it comes out of the ECU.
https://www.sau.com.au/forums/topic/308608-best-way-to-tap-into-ecu-wires/
STOP!!!! Dont cut the wires, just strip some of the coating off them and splice the wires you wish to tap in around the bare ecu wires and solder them together and
tape it up with some good quality electrical tape.
Picture care of evilution.co.uk
Picture care of legacygarage.com
Hope that helps. :thumbsup:
99 GTT, perfect, actually dont know why I didnt think of that its so obvious...
errno, i've seen those before, but im a bit skeptical, what if they cut in too deep, id worry about the wire breaking over time.
Thanks guys, off to do some soldering tomorrow and hopefully logging some AFRs
Edited by ascenion24
These join every phone line cable in NSW, look inside those cylindrical junction boxes and you will see hundreds of them, Ive used them on and of for the last 20 yrs and had no problems.
if they cut only the insulation then there not making contact with the copper, so they must come into contact and therefor cut the copper wire to some degree.
Im guessing you'd have to know the thickness of your insulation to get the right size of those joiny thingos... seems to much of a pain in the ass considering the consequences could be no connection or cut wire.
http://www.takakaira.co.jp/Main.aspx
Field one touch connector FTW!!!!!!!!
Not a cheap option but undoubtedly the BEST way
combined with the strip an solder method I think
If only temporary though Solder a bit of solid wire to ya leads
an push into the back of the plug
Edited by noone
a while ago i thought i'd give those little clip things a go, to install a SAFC on my old 32. driving up the motorway one day and the unit just died, hence my car died. not fun at 100kph. it was that little clip splicer thing that wasn't giving a good connection, and yes i did use the correct sized one for the cable i was splicing. i wouldn't recommend them to anyone.
what i like to do is cut the wire. strip the ends. slide a piece of heatshrink down the wire. solder it back up. slide the heatshrink over the join and shrink it down. you cant go wrong if you solder a wire properly.
Put your credit card against your leg, is it touching your leg, has it cut your leg.
Do you use M8 bolts to go onto a M6 nut, of course not, you use the correct size.
Ive connected up my shift light recently in 20 seconds, that included wrapping the connection in insulation tape, and, there is no drop in volts from the ECU to the light.
Ive used these for 20 odd years and if you do the job correctly you wont have any problems.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
