i have the set up u are putting on my car. 3076r with .82 housing and 38mm gate off standard exhaust manifold. it is an awesome turbo setup. on 16psi with step 1 cams and built engine i made 285kw with a very conservative tune (very little timing, rich afr's). My next step is to push the standard exhaust manifold as far as it can go to see if how far over 300kw it will go. I have noticed that most of the setups that stop making power around the 300 mark are using the .63 housing.
  • Replies 97
Posted Images
the stock cams are 350 capable, wait for ash to chime in. but im a believer anyhow.
stock manifold begins to hold you back above 300, the .63 doesnt seem to be an issue tho, its doing the numbers provided used with a good manifold and gate.
you wont get much more than 320kw out of the 0.82 version on pump fuel (98) you need E85 or some other exotic fuel/effective octane enhancer to get much more
Ye that's pretty much where the upper limits are going to be.
E85 would see you around the 350rwkw marker. Maybe a tad more, maybe a tad less, always subjective.
I was making 270rwkw @ 17psi with a bad 3" exhaust, factory cams, GTS-R manifold.
Held to 8000rpm no problems (GT3040/600hp).
I wish I'd had a chance to test it with a proper 3.5" exhaust that flowed nicely, would have seen over 300rwkw without much of a fuss was the general consensus and this was what… 4 years ago now.
Ended up making 370rwkw on 104 octane/24psi. Guilty-Toy made ~350rwkw factory head with a GT35 in a 3ltr not that long after.
45ULT - most setups (RB25/30s) have all run out around the 300rwkw marker factory exhaust manifold… a few have tried to go further and not really seen much gain. I believe some of those were using GT35's are well.
Change the manifold as well and then I think there was around a 20-30rwkw gain, and nicer midrange once everything was flowing inline with requirements so perhaps have a dig in the RB30 section of the forum.
I'm all for taking stock parts to untested waters, many said for ages you couldn’t make 300rwkw on factory cams (RB25 & 26)… and now there is a good number of cars over that. Some RB26’s making 380rwkw – factory cams!
It would just seem however the RB25 exhaust manifold just don’t have much to offer. That’s not to say there is anything wrong with it. Just don’t hope for much more than 300rwkw, and if you make more then count yourself lucky (but remember a manifold change, could well offer some decent $$ vs gain improvements)
what about extrude honing the exhaust manifold? has anyone had much sucess with this? I am still keen to see how much past 300kw i can get on the stock manifold before i switch to high mount. If i can get close to 320kw i might not even change the setup
yeah i realise this, i will look into a ETM item towards middle/end of this year.
aslong as i get close to 280-300rwkw fullboost 4000rpm nice strong mid range, set limiter to 7500rpm and plan on running 21psi if needed .
just hope its more fun then what i had before being the slowest 300kw ive ever felt.
Edited by l0WRB
yes that is correct one screws into the block and the other joins up to the metal piping that runs back behind the head. i want to know the thread size thats on the banjo bolt that screws into the block :)
brain fart, one of them screws into the block on the exhaust side (-6 fitting), the other goes behind the engine and plugs onto some coolant hose under the intake.
Dash 6 fitting like he said lol
Updates Justin?
placing order today for speedflow fittings / hose / firesleeve
me and tuner decided to weld the 50mm gate off the stock exhaust manifold now, saves hacking up a .82 turbine
we are going to try and fit a 4" intake aswell
then on the 5th we strap it 2 rollers and throw 21psi in it haha see what it produces
yes im replacing it with a -6 speedflow fitting barbed but wont the speedflow fitting need to screw onto a adaptor with -6 on the speeflow end and whatever thread on other end that goes into the block? i think im just a bit dumb lol
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
