i was hoping that someone can give me some feedback as what is good brand for replacement coil packs- i have ocational hesitation on take off and i have swapped them with second hand OEM ones, but really i'm pretty sure i will buy new ones shortly as this is really common on all skylines!
Apart from SPITFIRE is there any other brands that are more reasonably priced?
https://www.sau.com.au/forums/topic/308700-coil-packs/
I mean when i look at my application i think that spitfire may to over kill for my purpose. I will look into it and make a decision shortly.
The best feedback is from user rather than saleman/ company, so i value this greatly. Thank you
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5093630
^^ I have Splitfires and they are great!
I have seen Yellow Jackets for about $370 + and Splitfires are about $480 +
Ppl seem to think Yellow Jackets are good, if you don't want to spend as much on Splitfire, Yellow Jacks seem to be a good option.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5093944
When I was looking at coils I was tossing up between the three major brands. Splitfires, Yellow Jackets and the Just Jap coils all had much the same mix of reviews. I.e. great product, sporadic cases of people receiving faulty items but in all cases were replaced by the manufacturer. I reckon you'll be happy with whichever one you go for.
What's important to me is after sales support. I know Yellow Jackets back their product because after I posted an honest review of them on the forums (including report of a minor installation issue I had with one of the brackets on a coil) one of the Yellow Jackets guys came on SAU and queried me about it, offering to replace etc.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5094211
got yellow jackets for myself. fixed my misfiring i had for 2 years. i tried heaps of things including swapping 2nd hand coils, taping them up with high temp tape, 0.8mm gap plugs, rewiring my ignition power supply with high current relays and changing cas. i now run 1.1mm gap iridiums no probs. although i do remember having to file the bracket or something coz the yellow jackets were slightly bigger.
  • Like 1
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5094900
  • 2 years later...
sorry to bring up such an old thread but can someone confirm this?
are yellow jackets a straight fit? ie , nothing required to replace them?
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602097
They are a straight fit, no modification required. Just make sure, if you have an R33 GTS-T, that you identify whether you are series 1 or series 2 - coilpacks differ between these two models.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602182
lol
Most of them are probably made in the same Chinese factory and will work fine, but I have used YJs in 260-350rwkw cars with no issue. Even done back to back with Splitfires - the differences were negligible and some areas of the dyno graph were in the favour of YJs.
Plus Paul (Performance Wise) is a great guy, if you ever have issues he looks after you.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602220
as matt said, the brand probably means zero
any brand new coil pack will perform better than 15+ yrd old coilpacks
oem, splitfire, yellow jacket
i put splitfires in my ecr33 when it had misfire on boost, fixed it no problems
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6608563
I got a set of YJs from Performance Wise and about two weeks in two of them died. I contacted Paul (from performance wise) sent him some pics of them and he sent me out a full set of replacements within a couple days. The second set have performed flawlessly for the past year.
I recommend them and recommend getting them through Performance Wise. Yes, I had an issue, but Paul was great getting it sorted very quickly and without me having to take my car off the road (I sent him the defective ones after he sent out the replacements).
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6608689
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
