i was hoping that someone can give me some feedback as what is good brand for replacement coil packs- i have ocational hesitation on take off and i have swapped them with second hand OEM ones, but really i'm pretty sure i will buy new ones shortly as this is really common on all skylines!
Apart from SPITFIRE is there any other brands that are more reasonably priced?
https://www.sau.com.au/forums/topic/308700-coil-packs/
I mean when i look at my application i think that spitfire may to over kill for my purpose. I will look into it and make a decision shortly.
The best feedback is from user rather than saleman/ company, so i value this greatly. Thank you
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5093630
^^ I have Splitfires and they are great!
I have seen Yellow Jackets for about $370 + and Splitfires are about $480 +
Ppl seem to think Yellow Jackets are good, if you don't want to spend as much on Splitfire, Yellow Jacks seem to be a good option.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5093944
When I was looking at coils I was tossing up between the three major brands. Splitfires, Yellow Jackets and the Just Jap coils all had much the same mix of reviews. I.e. great product, sporadic cases of people receiving faulty items but in all cases were replaced by the manufacturer. I reckon you'll be happy with whichever one you go for.
What's important to me is after sales support. I know Yellow Jackets back their product because after I posted an honest review of them on the forums (including report of a minor installation issue I had with one of the brackets on a coil) one of the Yellow Jackets guys came on SAU and queried me about it, offering to replace etc.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5094211
got yellow jackets for myself. fixed my misfiring i had for 2 years. i tried heaps of things including swapping 2nd hand coils, taping them up with high temp tape, 0.8mm gap plugs, rewiring my ignition power supply with high current relays and changing cas. i now run 1.1mm gap iridiums no probs. although i do remember having to file the bracket or something coz the yellow jackets were slightly bigger.
  • Like 1
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-5094900
  • 2 years later...
sorry to bring up such an old thread but can someone confirm this?
are yellow jackets a straight fit? ie , nothing required to replace them?
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602097
They are a straight fit, no modification required. Just make sure, if you have an R33 GTS-T, that you identify whether you are series 1 or series 2 - coilpacks differ between these two models.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602182
lol
Most of them are probably made in the same Chinese factory and will work fine, but I have used YJs in 260-350rwkw cars with no issue. Even done back to back with Splitfires - the differences were negligible and some areas of the dyno graph were in the favour of YJs.
Plus Paul (Performance Wise) is a great guy, if you ever have issues he looks after you.
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6602220
as matt said, the brand probably means zero
any brand new coil pack will perform better than 15+ yrd old coilpacks
oem, splitfire, yellow jacket
i put splitfires in my ecr33 when it had misfire on boost, fixed it no problems
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6608563
I got a set of YJs from Performance Wise and about two weeks in two of them died. I contacted Paul (from performance wise) sent him some pics of them and he sent me out a full set of replacements within a couple days. The second set have performed flawlessly for the past year.
I recommend them and recommend getting them through Performance Wise. Yes, I had an issue, but Paul was great getting it sorted very quickly and without me having to take my car off the road (I sent him the defective ones after he sent out the replacements).
https://www.sau.com.au/forums/topic/308700-coil-packs/#findComment-6608689
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
