Hi All,
Looking to seek some knowledge on an overheating problem with an Auto R33.
There was lots of rust in the system, had to flush the radiator numerous times and also replaced the thermostat whilst I was at it. After flushing the whole system out and putting in the new thermostat, the water still boils. Im not too sure how long the rusty water has been sitting in the radiator, but appears to be a long time. Im not too sure if it would be a head gasket either?
Even with the new thermostat, the water tends to spit out intermitently, rather than flowing like a river. This is only when the engine is reved and leaving the top hose off to check. There is no white smoke coming out the exhaust so I dont think it is a head gasket. The only things I can think of are;
- Water pump
- Radiator possibly clogged from all the rust
- Head gasket
Hopefully someone can shed some light. Im sure it is one of those 3, hopefully number 2!
Many thanks,
Jason
https://www.sau.com.au/forums/topic/308751-overheating-auto-r33/
Thanks Guys.
If the car isnt blowing any smoke, the oil looks fine, whats the probability it is a head gasket?
The temp is fine with the top hose off as im constantly running water through the system when im flushing, i.e not presurised. When I put the cap on, reconnect the top hose and take it for a drive, then the heat goes up and you can hear the overflow bubble.
So the blocked radiator is more than likely the problem?
Jason
if it was the headgasket you would at least get some sort of smokey haze when starting the car after it had been sitting for a while, so i would leave it as being the last thing on the list to look at.
i would start with the radiator as even if it isn't the only cause, it is probably going to be a major cause and getting it sorted would be a good thing either way. i would also get a new radiator cap just to see what that does. they are pretty cheap so if it doesn't change things there it isn't much of a loss. just make sure that you get a cap rated to the same pressure. i'm not a fan of using caps with higher pressures than standard as it can cause issues in other areas.
also, this may sound a bit silly, but you are putting coolant back in the system aren't you? you aren't just filling it up with just water? if you are, then get your radiator cleaned (as it will probably be rusting up pretty quickly now) and then get some proper coolant.
^ Thanks,
I ended up putting in a new radiator, got it all hooked up and just running water through the system. This was a weird problem though, since pulling the radiator out and putting the new one in, the auto transmission now has issues, ie feels like it just slips when trying to drive? Car barely moves, engine revs but car barely gets anywhere, feels like a really bad slipping clutch in a manual, without the smell.
Note that the radiator actually has 2 extra lines that run into the bottom because its auto. Not entirely sure whether this has had any effect?
On a side note, the engine still overheating :)
Any help would be appreciated.
Those two extra lines are the auto transmission fluid cooler.
If you dont hook them up, the auto will pump out all the trans fluid within a minute of starting the car, you'd know about it.
If the lines aren't in the new radiator and you've blocked them up, I'd say your auto isn't getting fluid and the cause of those symptoms.
If the lines are leaking and coolant is getting into the auto, it looks like its manual conversion time - chances are the auto will be well and truly screwed by now.
It could be something as simple as the trans has lost some fluid and is now low, while the radiator was being changed. Check trans fluid level.
Thanks Bozz,
I think it will be the transmission fluid as I did start the car without the radiator connected just to move it, probably explains the red stuff on the driveway! Grrr... Is it easy to top up the transmission fluid?
Jason
I dont know how Nissan auto's work, hopefully someone can confirm/update the following comments. This is a generic process for most autos as long as there is a dipstick to measure fluid level.
Also be sure which fluid is going in, whether its the usual Dexron III or something else like TQ95 or whatever. Most likely Dexron III but dont chance it or it could cost you big dollars if you get it wrong.
There should be a dipstick to check the auto's fluid level near the firewall. Pull out the dipstick (it will be long) and wipe it clean
Reinsert all the way and remove it again. Check fluid level, it may have writing like Hot and Cold (or H C etc) which is the level when the transmission is hot or cold. There should be a level marker, usually crosshatched, the bottom of the crosshatch is the minimum level, the top of the crosshatch is the maximum level.
With the engine off, top up the trans fluid to the minimum level, let it sit for a minute and re-check the levels. Once it settles at the bottom, start the motor, firmly apply the handbrake, put your foot on the brake and move the selector lever through all the gears. Let it sit in each gear for 5 seconds or so.
Turn off the motor and check levels again. Get it to the minimum marker.
Start the motor, foot on brake and cycle through all the gears again.
Put it into park, leave the engine running and check the level. Now top it up to the maximum (or full or whatever) marker on the dipstick. It'll be a small amount of fluid, perhaps 1 litre from the minimum to maximum mark. Do not overfill it!
Check again - the fluid level is usually checked while the engine is idling. Once it settles at the maximum point, it should be good to go.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
