Just out of curiosity, will the factory radar cruise control do an emergency stop if its set to cruise and a car pulls out in front? Or is there only a certain percentage of braking forced which can be applied by the cruise control? I would be guessing the latter?
https://www.sau.com.au/forums/topic/308786-m35-radar-cruise-control/
Im not sure, can you test it for us? :) Wont it just roll off the throttle?
I do know the new volvo will do a full emergency stop, not sure its a good idea though. I always wondered what would happen if a bit of newspaper blew onto the road or a roo bounced past. Could cause problems for the car behind. :D
Exactly my thoughts! I've read some where on here that the system does in fact use the brakes to slow the car if needed, but just not sure if it will do an emergency stop. Hmm... yeah will have to test it out when I get the car... but I'd say it would only be allowed to apply a small amount of braking force. Another question would be whether it uses the speed sensor and brakes when going down hills to maintain the correct speed. But I'm guessing if they've gone as far as to use a radar they would've implement that for sure...
Edited by Vesza
It would be a great package if that's the case. Shame about the obtrusive radar sticking out the front.
You could always put big wheels on to bump up your speed, if needed. 22 inch rims should do it. :D
Yeah the radar grille looks like barf!
haha, yeah or I may look into tampering with the speed sensor. Was just thinking to myself.... an even better option would be adding GPS guided cruise control. So when I'm driving to Melbourne I can do 150km/h and automatically slow down for the speed camera's at each bridge :D
one way to test is to setup a pile of cardboard boxes and then 'cruise' into them and see if it stops!
or foam, or something else soft. maybe a group of people?
Funeral gathering?
Saves time!
(didn't put in my first or second thoughts.... would probably have gotten a warning :ermm: )
Edited by iamhe77
  • 2 months later...
For those interested, the factory radar cruise can apply the brakes HARD if it feels the need (it has activated the ABS in mine before), and can slow the car down to around 5km/h or so. It might be able to stop completely, though I haven't been game enough to let it try.
If while driving you catch another car and the speed difference is too great, it will beep to indicate that another car is within the range of the radar, and either roll off the throttle or brake gently to maintain the safety gap distance you have set. If the speed difference isn't too high, it will just match speeds with the car in front without a beep.
The safety gaps are "far, very far, and stupid far"
It will only apply the brakes to maintain the set cruise speed if you are following another car, so on a steep downhill it will basically free roll. At 120km/h the cruise beeps and disengages.
Occasionally it will have a fit at some odd-angled road signs, when driving into morning/evening sunstrike, and it will sometimes 'see' oncoming traffic as being in your lane. Most of the time these events just produce a beep, as the object passes by and the radar clears. In some cases it will stamp on the brakes, though again only for a brief moment (though this is annoying for people following)
Fortunately in all cases it beeps which gives you time to react. Once you know what to look out for, you can predict it's behavior.
The brakes are activated by an actuator which actually pushes the brake pedal, it's creepy to feel it moving.
The cruise won't engage below 45km/h, or if the gearbox is in manual mode or snow mode, or if the windscreen wipers are on normal or fast. It also won't engage if the radar unit is obscured/disconnected.
It will disengage if the front wipers are turned on for more than 10 seconds or so (though it is happy to operate if the wipers are only on the intermittent setting). It will also disengage if the rear wheels slip, if the sensor becomes too dirty (following cattle trucks etc), if you corner too hard, or if the car aquaplanes. The cornering one I discovered playing on a track - you'd have to be *really* pushing on the road.
It must have a G or steering angle sensor somewhere also, as it will often allow the speed to drop while cornering, and then accelerate back to the set speed once the wheel is straight again. I guess this avoids ending up with a heap more power being applied mid-corner.
It's not without it's problems, but it's a damn clever system. Just a shame it can't be set over 110km/h - my speedo reads 10km/h low at 100km/h.
Yerp, discovered pretty much exactly what you wrote, about mine. Except haven't tried the hard cornering stuff. My speedo is also 10km out. Yeah the radar doesn't work too well when there's too much water spray following other cars, hence why it's designed to disengage if you set the wipers on anything else other than intermittent. I also get the same random blip of the brakes here and there (pretty rare though). As you said, would be nice if it could be set over 110km/h!
Also, depending on the vehicle shape and height, sometimes it won't detect the car until much closer than set... doesn't happen often, but still need to be on your toes. I haven't had it brake hard enough for the ABS to kick in, but I have a feeling once it got real close it would finally get a better radar bounce back and stop in time... just not game to test it lol.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
