hey guys just wondering if someone could help me with the installation of a drift brand monster tacho i have to be put into a 1987 holden astra like the nissan pulsars it has a ca18de engine and i dont know where the the wires go
i know
red=positive
black=negative
but im unsure of the green and white wires
hopefully someone can help me
thanks in advance
https://www.sau.com.au/forums/topic/308804-drift-brand-tachos/
why are you putting one in anyway?
stock one should work fine...
not to mention, id question the accuracy of it too...
its not going in my skyline its for my partners car its a holden astra and there is no tacho in it
sorry to ask guys but does anyone know how to find the ill and rpm wires cos i have no idea
the ilum pick up will be easy, use the cigaret lighters light ring, or the dash clusters lights ppower, basicly anything that lights up on your dash when u turn your head lights on, use that,
as for your rpm feed as it dosnt have a tach as standard you should be able to pick it up from the ecu wireing loom somewhere, but you will have to look it up and find out what exact wire,
maby search the net for the wireing diagram, or register on a slivia form
hope this helps
hope this helps
yeah thanks for the help guys i have been searching the net trying to find a wiring diagram for it but so far no luck does anyone know where id be able to get one
thanks again for all the help
may i ask why you're putting a tacho in this car?
is it because it has a ca engine?
no its not because it has a ca y would that be the reason seriously i wanna put it in because its mounted in the car doing nothing and the car does not have a tacho as standard so y not just wire it up but anyway thanks to the guys the has been helpfully and not the people that have a winge bout it.
so with the rpm wire will that get 12v as well
haha no need to be defensive, just curious
After all, you'll look like the douche bag, not me
to be honest i dont care because everyone has there own opinion and im not driving the car anyway all im doing is fixing it up and selling it anyway to make money to either be put into my 34 or into my house and if your not gonna be helpfull dont reply because i dont wanna hear all the crap bout being a douge bag for having a tacho or anything like that
i posted the topic to get help with things i dont know about not hearing your crap
any help appreciated guys.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
