-access the CONSULT port, bottom right side of dash behind flip down door.
-ignition OFF
-ground bottom middle terminal using a wire.
-ignition ON
-observe flashes (also beeps) of ABS light
-it will start with '12', (1 long flash then 2 short.)
-it will then flash the fault codes.
-to clear the codes, whilst in this diagnostic mode, disconnect the grounded terminal, then ground it 3 or more times, for at least 2 sec, within 12.5 sec. restart diagnostic mode to check if thwey have been cleared. May take a few attempts before the codes clear.
21 Front right wheel sensor (open circuit)
22 Front right wheel sensor (short - circuit)
25 Front left wheel sensor (open circuit)
26 Front left wheel sensor (short circuit)
31 Rear right wheel sensor (short circuit)
32 Rear left wheel sensor (short circuit)
35 Rear left whel sensor (open circuit)
36 Rear left whell sensor (short circuit)
41 Front right outlet solenoid valve and circuit
42 Front right inlet solenoid valve and circuit
45 Front left outlet solenoid valve and circuit
46 Front left inlet solenoid valve and circuit
55 Rear outlet solenoid valve and circuit
56 Rear inlet solenoid valve and circuit
57 Battery voltage
61 ABS actuator motor and motor relay circuit
63 ABS acutuator relay circuit
64 FR & RR G sensor 1
65 FR & RR G sensor 2
66 FR & RR sensor 1 or 2
68 G sensor voltage
69 Side G sensor voltage
71 ATTESA E_TS PRO/ABS control unit and circuit
72 Throttle position sensor
73,74 E-TS/LSD actuator motor
76,77 Pressure switch
78 Air bleed switch
79 Oil level switch
91,92,93 E-TS solenoid
94,95,96 E-TS fail safe solenoid
97,98,99 LSD solenoid
Hey Mat, welcome to SAU, and to the Stagea section of the forums.
First things first, do a quick search for your problem in this section of the forums, and you should be at least be able to find a link with info for getting ECU codes. Once you do that, see if anything matches what's previously posted. If you can't find any details about what corresponds to the codes given, post the details on here and see if anyone else can help!
yeah ive searched the forums and everything ive tried hasnt worked.
ive tried the consult port and it doesnt stop flashing i counted 102 before i gave up.
i wouldnt think a slight tire differnce would affect the system.
there is a differnce by 2.06% but wouldnt think that would be enough to affect the system??
or am i wrong?
or am i wrong?
From the million times this has come up on this forum, I'd say stick to the same size rims/tyres for all 4 and you wont have any problems. The ATTESA system apparently doesn't like differing rolling diameter front vs rear OR differing tyre width...it allows enough leeway for uneven tyre wear, but thats about it.
or am i wrong?
flat(er) tyres also cause the jerkyness and even bald vs new tyres
see if you can throw on some rims from a different car which are all identical
  • 1 month later...
yeah i thought the same thing. ive tried the consult port and i even have a cable but i dont get any fault codes,
the fault clears as soon as i turn the car off, and the light wont come back on untill i drive about 20-30km's
ive noticed a small amount of fluid araound the bottle in the boot so ill drain it and check all the lines and replace the fluid.
  • 4 weeks later...
before you do anything make sure the fluid level in the ATTESA reservoir is between full and empty, and that you don't have any leaks so that the system can pressurise.
  • 6 months later...
  • 6 months later...
  • 4 years later...
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
