-access the CONSULT port, bottom right side of dash behind flip down door.
-ignition OFF
-ground bottom middle terminal using a wire.
-ignition ON
-observe flashes (also beeps) of ABS light
-it will start with '12', (1 long flash then 2 short.)
-it will then flash the fault codes.
-to clear the codes, whilst in this diagnostic mode, disconnect the grounded terminal, then ground it 3 or more times, for at least 2 sec, within 12.5 sec. restart diagnostic mode to check if thwey have been cleared. May take a few attempts before the codes clear.
21 Front right wheel sensor (open circuit)
22 Front right wheel sensor (short - circuit)
25 Front left wheel sensor (open circuit)
26 Front left wheel sensor (short circuit)
31 Rear right wheel sensor (short circuit)
32 Rear left wheel sensor (short circuit)
35 Rear left whel sensor (open circuit)
36 Rear left whell sensor (short circuit)
41 Front right outlet solenoid valve and circuit
42 Front right inlet solenoid valve and circuit
45 Front left outlet solenoid valve and circuit
46 Front left inlet solenoid valve and circuit
55 Rear outlet solenoid valve and circuit
56 Rear inlet solenoid valve and circuit
57 Battery voltage
61 ABS actuator motor and motor relay circuit
63 ABS acutuator relay circuit
64 FR & RR G sensor 1
65 FR & RR G sensor 2
66 FR & RR sensor 1 or 2
68 G sensor voltage
69 Side G sensor voltage
71 ATTESA E_TS PRO/ABS control unit and circuit
72 Throttle position sensor
73,74 E-TS/LSD actuator motor
76,77 Pressure switch
78 Air bleed switch
79 Oil level switch
91,92,93 E-TS solenoid
94,95,96 E-TS fail safe solenoid
97,98,99 LSD solenoid
Hey Mat, welcome to SAU, and to the Stagea section of the forums.
First things first, do a quick search for your problem in this section of the forums, and you should be at least be able to find a link with info for getting ECU codes. Once you do that, see if anything matches what's previously posted. If you can't find any details about what corresponds to the codes given, post the details on here and see if anyone else can help!
yeah ive searched the forums and everything ive tried hasnt worked.
ive tried the consult port and it doesnt stop flashing i counted 102 before i gave up.
i wouldnt think a slight tire differnce would affect the system.
there is a differnce by 2.06% but wouldnt think that would be enough to affect the system??
or am i wrong?
or am i wrong?
From the million times this has come up on this forum, I'd say stick to the same size rims/tyres for all 4 and you wont have any problems. The ATTESA system apparently doesn't like differing rolling diameter front vs rear OR differing tyre width...it allows enough leeway for uneven tyre wear, but thats about it.
or am i wrong?
flat(er) tyres also cause the jerkyness and even bald vs new tyres
see if you can throw on some rims from a different car which are all identical
  • 1 month later...
yeah i thought the same thing. ive tried the consult port and i even have a cable but i dont get any fault codes,
the fault clears as soon as i turn the car off, and the light wont come back on untill i drive about 20-30km's
ive noticed a small amount of fluid araound the bottle in the boot so ill drain it and check all the lines and replace the fluid.
  • 4 weeks later...
before you do anything make sure the fluid level in the ATTESA reservoir is between full and empty, and that you don't have any leaks so that the system can pressurise.
  • 6 months later...
  • 6 months later...
  • 4 years later...
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
