Hey...
I currently own a toyota soarer, and am looking at coming over to the dark side and getting a Skyline V35.
Living in Perth i found owning a Soarer, got expensive due to lack of parts and lack of people that knew what to do when it came to servicing the Soarer. I was just wondering if it would be a simliar case with the Skyline V35, or are the parts similar to the Nissan 350/370 Z ?
Has anyone also experienced any problems with these cars at all?
Any information would be appreciated
Regards
Anthony
aka NAASTEE
https://www.sau.com.au/forums/topic/308814-skyline-v35/
Hey...
Regards
Anthony
aka NAASTEE
I think the lack of posts to this thread might be an indicator...however if you try the V35 section of the forum you may have more luck.
I have a M35 stagea which shares some things in common with the V35 skyline - same auto gearbox for example (The M35 stagea is the last in the stagea wagon line-up and this model is built off the same platform as the V35).
All up they'd be pretty reliable and they do share some parts with the 350z. Servicing should be pretty straightforward - should use the same oil, filters, plugs, etc as a 350z because its roughly the same engine. Nissan use the VQ35 in loads of cars (with varying power output) so you generally shouldn't have an issue finding bits for the engine at least.
In any case, you can get parts from Nissan - if they dont have them in stock they'll order them from japan for you - usually within 10 business days.
Another plus is that these cars were also sold as LHD versions in america so there is a lot of info from american G35 forums etc. You can get the full service manual in english for example (google it and you'll find it pretty easy - it comes as a heap of PDFs).
Good luck with it :ermm:
https://www.sau.com.au/forums/topic/308814-skyline-v35/#findComment-5095708
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
