Have up for sale my pride and job :( I am one fastidious owner, Every area has been looked at in terms of modifications, engine, brakes, suspension. It has the power and the handling to go with it. Serviced every 4000kms, with only top quality fluids, And all engine modifications have been done in the last 6,000 km's. The car acquired a RWC about 2 months ago and will not have any problem obtaining another one. Car has never been in a accident and no finance owing at all on vehicle.
Car is making somewhere in the vicinity of 230 - 240kw's. Any questions please don't hesitate to email or contact me on my mobile. I am interested in swaps but they must be with cash adjustment my way as I am looking to move away. Also have no problem delivering the car to the mainland
Run down on some of the things the car has :)
1999 Silvia S15 Spec R JDM
6 speed Manual
Nismo Front strut brace
Rear strut brace
Nismo struts
Nismo rear Camber arms
Slotted DBA Rotors
POWER FC D-JETRO
X-Force front pipe, High flow cat, cat back exhaust
GTR front mount intercooler
Turbo tech Boost Controller
Apexi POD
Custom Stainless steel airbox
Blitz hot pipe
Blitz silicone joiners
GKTECH Dump pipe
Braided oil line
Bosch 040
Greedy induction pipe
Trust T518z turbo
Tune agent manifold
Nismo 740cc Injectors
Nismo Super Coppermix twin plate clutch
Nismo Lightened flywheel
Top stage carbon fibre ABS unit cover
Pioneer DVD 7inch in-dash Touch screen
Polk Audio Splits
Type R coaxils
Kenwood 4 Channel Amp
20 Inch by 10inch Koya R1 GT's
Full Pearl White Respray
25mm spacers
Rolled Front Guards
Custom Pumped and flared Rear Guards
Fibreglass black eyelids (not fitted)
M-Sports front bar
Uras rear bar
Uras side skirts
Fibreglass vented bonnet
Full Alarm System with remote start
Shaved all badges
Shaved boot
Silvia Floor mats
Tinted windows
DRFT Gear Knob and Leather boot
Xenon white Headlight bulbs
Smoked Black rear taillights
Smoked Black Side guard indicators
Original s15 owners manual
Interior is in excellent condtion/ non smokers car
Bad points:
Front bar has a scuff mark from where it scrapped on a driveway
On the rear quarter it has a 3cm scratch that was touched up with some paint ( by the previous owner)
Rear bar has a few very small light cracks (not all the way through just shallow)
Do have a tin of pearl white paint to touch up these little imperfections
Sure there is a few other little things that I have forgotten that I will update when they came back to me
Car is located in Tasmania
Price $26,000 o.n.o
Car sales link CLICK!
https://www.sau.com.au/forums/topic/308867-1999-nissan-silvia-s15-spec-r/
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
