  • Replies 135
Yep my car is taking priority for once!
Once its going again, which should be in a couple of weeks, we can start sizing the wheels for the sil80, buy some, and start on body work.
Also at some point we need to pull the motor out and fix all the oil leaks too...and fit the new turbo.
Looking at the pics, im guessing you have a tdo5hr(r means reverse rotation) , with a tdo5h exhaust housing which is why its spinning backward, it may still be a good turbo.
Edited by Adriano
yep you are right but still makes is a useless turbo for us unfortunately. We might still be able to sell it off seperately.
  • 3 months later...
WOW!! Update!!
We spent the weekend fixing the oil leaks like we said we were going to. What a job!!
We ripped the engine out friday night and removed the upper and lower sump, and the front timing cover.
Cleaned all the old sealant off and washed the surfaces up.
Re-sealed everything and whacked it all back together.
Saturday we also ditched the backwards-spinning turbo and fitted our new one! Its a KINUGAWA TD06SL2-20G! Nice external gate 3" vband rear which suited us perfectly.
We sourced a Turbosmart 38mm gate as well and that went on too, after realising the manifold flange for it wasnt flat we had to machine that flat too.
Dropped the motor back in and I made a new DUMB pipe to suit the new turbz. Love using vbands theyre so much easy to work with.
Today got it running again and ran some cooling system cleaner through everything as we found alot of gunk in the cooling system when we removed the engine.
We also got FLUTTERZ!!!..bro.
Next is wheel sizing and some body work.
  • 3 months later...
Man it has really been a long time since we did much on this car! Been busy with WTAC etc and ive been doing a few Winton and PI days which take up a bit of time.
Anyway, we have some progress!
New wheels!! Varsstoens!
18 x 9.5 +22 and 18 x 10.5 +15!!
Pretty FAT!
Rear:
Front:
This weekend we are going to paint all the jambs, inside the doors and hatch and the rocker cover, and paint the roof, mirrors and bonnet vent black.
Cant wait to get this thing done!
There will be another update to follow soon!
So we have another update! Lots happening! Lots of pics!
Last weekend we got alot of painting done! Jambs, insides of doors and hatch, roof, mirrors are all done.
We set up a temporary paint booth in my garage to minimise overspray going on everything in the garage..
We started off with all the orange to be painted on the car:
Masked up ready for paint
Jambs painted
Then we moved onto painting the doors, hatch and petrol cap inside.
Doors and hatch inside result
Then on Sunday we continued on to the roof. He had to do a few little repairs and primer before it was ready to paint. We also had to prime the rocker cover because it was a bit too ratty to paint.
We also cut the bonnet vent out (thanks Paul for the freebie!) and prepped it for black paint too.
The roof turned out really well! Very shiny! Were very happy with it. It has alot of dust and crap in it but as long as its shiny thats what matters. The finish is really good. Not bad for first timers!!
Doors back on and rubbers and other stuff back in
We got alot done and really happy with the results. Getting closer now!
More bodywork coming up soon.
  • 3 weeks later...
Who are these mugs?
Man that seems sooo long ago now! Can't believe this build has been going for over 3 years now haha.
Body work is coming along nicely. Hopefully the whole back of the car will be orange by the time the weekend is over. Prep work sucks... but it's good to see the progress.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
