Hi All,
Ive got the following for sale:
Tomei Poncams 264/264 9.15mm Lift (In&Ex) - $650
Tomei Procams 270/270 10.25m Lift (In&Ex) - $750 BRAND NEW IN BOX
Reason for selling is i am looking for bigger cams, 270/270 10.8mm lift.
Thanks,
Gordon
https://www.sau.com.au/forums/topic/308877-tomei-cams/
doesnt say what engine they are for and how many K's they had , and there are no pictures either ?
Hi GlenJamin88,
They're on the car for about 3000kms. Its for an RB26DETT.
It really doesnt matter as they dont even get worn or damaged.
I can provide pictures however, if you're really interested.
Need these gone everyone for my new set of cams (Tomei 10.8mm) :)
Prices are negotiable!
https://www.sau.com.au/forums/topic/308877-tomei-cams/#findComment-5098073
Are you genuinely interested in the cams? I'll post up pictures tonight of them, they're still brand new in the box.
What kind of pictures do you want?
I am intreseted in the cams i would like to see a few pic or you can give me a call on 04070000098
Cheers
Zak
https://www.sau.com.au/forums/topic/308877-tomei-cams/#findComment-5102704
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
