It's cheaper to export you out of this country for asking vague questions.
Bit harsh on a newb with 10 posts to his name.
All depends on what your after, how much you want to spend and how long you can wait.
The good importers call give you a rough dollar figure for what your after, match that to a local car price and you've got your answer.
Do a search like "how much did it cost to import", that should give you lots of threads to look through.
It is cheaper and if your confident in a car you can save yourself alot of money. Its also more risky and alot of work. If your not confident with the process, lots of small things can add up, you should probably get an agent to help.
guys - before everyone gets consumed in this discussion, I think you'll find the best answer is this...
'welcome to the forum newbie. I notice you posted several threads all at once, most of which were meaningless, and probably simply because you need a minimum of 10 posts in order to PM someone, or even reply to a PM. Thumbs up for some relatively innocuous thread bumps, but please - at least next time put a question mark after your statement, so that it gives the remotest appearance of being genuine. Enjoy your time on the forum and hope you got that PM sent.....'
(I know this because I had to do the same thing)
Unless you want something new-ish or rare, it's generally cheaper to buy local. Once upon a time it may have been different, but it's pretty damn hard to land and comply a car for less than $10k, regardless of what it is or how much you paid for it over there. If you're talking about an R32, R33, Soarer, S13/14, 180SX, this generally isn't worth it, because they can be had locally for less. However, if you're talking about an R34, S15, Stagea, Legnum, Supra... It may be a little different. Just look into the costs of each man! And be more specific lol...
I'm assuming you're talking about importing from Japan, to Australia, and having it complied for street use.
Also depends on if it's pre/post '88 (I think it was? or '89). Import laws and therefore costs change around there.
I can confirm that it is far more expensive to import then to buy locally (I'm finishing importing myself as a type this, car gets rego'd next week). Because importing can be a legnthy process (months obviously) you end up buying more and more stuff for your car before it has even arrived (E.g Bonnet, Wheels, Seats, Coilovers, Boost Controllers, Air Filters, BOVs, Ganadors...). In the end what you saved on your car you spent on mods and then some before you can even fit them :)
Because importing can be a legnthy process (months obviously) you end up buying more and more stuff for your car before it has even arrived (E.g Bonnet fins which stick on with 3m tape, chrome hubcaps, UNIT stickers, Ed Hardy Carseat Covers, Aluminium GT wings, Fuel Saver Tablets, Screw on Exhaust Trim Tips with LED's, LED Valve Caps, Green Coloured Headlight bulbs which are inexplicably expensive considering they're for "offroad use only", RM WIlliams Mudflaps. "Spotties", "Southern Cross" stickers. "FUUCK OFF WERE FULL" stickers. Nankang tyres when they're on special. and getting the car here and realising you don't have enough money to insure it...).
^^^hell yeah. importing is wicked fun! haha (im about to import myself - am i showing yet? it's still early days though but soon i'll have that healthy "i've imported" glow about me.
and guess what else - i won't put up a thread saying "my journey" and i'm also not going to post a build thread!
original huh.
Edited by Mr Eps
I can confirm that it is far more expensive to import then to buy locally (I'm finishing importing myself as a type this, car gets rego'd next week). Because importing can be a legnthy process (months obviously) you end up buying more and more stuff for your car before it has even arrived (E.g Bonnet, Wheels, Seats, Coilovers, Boost Controllers, Air Filters, BOVs, Ganadors...). In the end what you saved on your car you spent on mods and then some before you can even fit them ;)
Haha just bought wheels and coilovers for my Cube, hasn't even gone on a boat yet!
I fail to see the problem with this ;)
In answer to OP question. Maybe?
lol. so did I. :cool: depends on what we are talking about importing. sometimes yes. sometimes no.
given the bloke hasn't posted again I'd say he's happy with the response. :) it would have been a bit easier to give a more useful answer if we at least knew what type of car he wanted.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
