i think mines due for a service,
got it at 47,000Ks and its around 52,000Ks
How often do you service your v35s and where ?
I just did it at unique auto sport after 9000 something km. it is $250 because everything else is still in good condition except the engine oil stuff.
where is it mmm.... use google=)
just did my service at 33000KM's
200 bux at Pro concept in West Ryde
oil and oil filter every 5000km's
Last time I quote for service in Pro Concept and the guy listen the phone just said around 400 to 500 for oil changes coolant changes and brake fluid changes and i just hang up.
does it matter where i get it serviced though ?
their gonna do same thing to it anyway right?
like K-Mart and others would be $130
Pro-Concept is $210
Personally I'd say no, it shouldn't matter.
My advice -
Things like oil changes/filters etc are pretty easy to do at home.
If you want to do things like a full fluids change - brakes, diff gearbox etc
Find a mechanic you know is decent, buy your own fluids, take them in with the car, and watch them change it.
There is nothing special about the V35, that means you should be paying extra. Anyone who tells you different is trying to rip you off. Yes you will pay extra for better oils etc, but if both places are using the same stuff the price should be similar.
By buying your own fluids, you may be able to get them cheaper if you shop around, and you avoid the place adding there own little charge on top.
If the workshop can get parts cheaper, then make sure you actually see them putting those parts in. ie, you don't want to be paying for Motul 300v engine oil, and they just put castrol magnatec in. :-)
at the end of the day, its just another car.
To take the oil out, you undo the sump plug - just like a commodore/falcon
To put the oil in, you unscrew the oil cap and fill - just like a commodore/falcon
seems everyone says every 5k, but the manual says every 15k.. any particular reason why?
My S14 I used to do every 5k, but thats coz it was turbocharged.. think the manual for that said every 7.5k..
Just keep an eye on it. You can tell if your oil is being used/burnt and change the service interval to what suits.
As a guide though, i have an Aus 04 Maxima, which has the VQ35 engine (but de-tuned) and the service book recommends every 5000km for oil changes.
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
