Item Summary: silver 1996 R33 GTst with minor mods
Reading: 98500km
Condition: Used
Reason for Selling: upgrading 2 a new toy : )
Asking Price: $14500
Delivery Methods: PickUp
Contact Info: 0431 564929 (luke)
Engine/Drivetrain
Pedders lowered springs (40mm)
Trust intercooler kit
Trust Type-s blow off
HKS SuperDragger cat back exhaust 3.5"
jjr 3" ss split dump pipe/front pipe
Exedy Heavy duty single plate clutch
Rda slotted front rotors
3" ss intake pipe w/ ss pod filter
R34 turbo
New ngk platnium plugs
Candy orange rockercovers
Polished n detailed everything
Interior
Almost perfect condition sr3 recaro seats in red
Red leather gearboot n handbreak boot
Trust gear knob
Exterior
Standard s2 apart from gtr wing and s2 4 door grill
19x8.5, 19x9.5 tenzo-r gt-05 wheels black w/ chrome lip
Sound System
Alpine Type-s 6.5" splits front
Alpine Type-s 6.5" 2-way back
2x Alpine v power Amps
2x 12" Alpine Type-S Subs
Alpine top of the range fold out
touch screen dvd plater
Other
Full Mongoose alarm system
also comes with new top secret front bar and copy greddy plenum
Awesome car, very quick n reliable, has never had any problems. car needs 2 go make me an offer comes with 10 months rego
I will make u offer 7k
no need the rego
let me know
cash take it from u this saturday
hahaha. why so high? why not just offer him a pack of chips and a can of coke? small chips. not those big expensive ones!
hey mate nah im sweet with an inspection, havent done 100k servise yet but previous owner changed the timing belt and i service it every 5000 kms.
nah dont smoke and its never been tuned, still running standard boost.
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
