I have noticed that cruise control is a very rare option on the M35 and it is even rarer to find a car with both the audio and cruise control buttons on the streering wheel.
In the USA the Infiniti G35 looks to have exactly the same steering wheel but with both audio and cruise control buttons as standard.
Does anybody know if it would be possible to buy a G35 steering wheel from the USA, fit it to an M35 and use the audio buttons to control an aftermarket head unit and the cruise control buttons to control an aftermarket cruise control unit such as the AP800?
Edited by neotropic
https://www.sau.com.au/forums/topic/308910-m35-steering-wheel-controls/
You don't need a new steering wheel. You get these features fitted locally.
The Stereo unit is about $60 and there is a DIY on the forum for this.
The Cruise control is not a DIY, but Chris Rogers (Audio Express) can install cruise control and uses the factory buttons so it is a very neat job. Cruise on these cars is not a cheap option as the throttle is controlled electronically. But it is good to have IMO.
Chris is on this forum so you can send him a PM or get his phone number from my signature below.
Cheers
Andy
Cheers
Andy
Where does one get the steering wheel controls for the stereo. . .
How much is the cruise control. . I agree worth it for the long trips and better on fuel I would suspect. .
Chris rogers for both stereo controls and cruise control. I believe it is around $900 for the cruise control.
Cheers
Andy
Cheers
Andy
Hi Andy, I was wondering if you could post the link to the DIY for the stereo controls... I can't seem to find it... Cheers
ooopppss. sorry my bad. I is not on here. I mus have been told on a phone call.
Before you start this procedure make sure you turn your stereo off and the CDs are correctly parked in the mechanism.
The basic procedure is.
1. DISCONNECT BATTERY
2. remove screws on either side of steering wheel, on the back facia of the wheel behind a little pop in bolt cover. This screw is a torque head screw (star pattern). This can be quite tight as it has lock tite on it.
3. The centre of the steering wheel will no come out (the airbag), as you pull out you will see a plug connecting it to the car on the top edge. This plug has a safety mechanism to stop the plug poping out. The black part of the yellow plug needs to be lifted up to release the plug. Put the Airbag aside.
4. You can now see the horn mechanism that floats on the inside. On the left side you will see a grey plug with a wire running from it connecting to the horn mechanism. Remove this grey plug as your new controller will replace this.
5. Undo the central nut holding the steering wheel in place.
6. Once removed you will need to undo the screws that hold the horn mechanism in place, this will release the pannel that covers the access to back of the steering wheel.
7. You should now have access to the back of the steering wheel to undo 2 screws that hold the silver blank in place. Undo and replace with controller.
8. Run wires around and plug grey plug into hole.
9. Do the reverse of dissembly to complete conversion.
This should not take more than 1 hour.
Good luck.
There is good thread on the G35 Driver forum in the USA which is a guide to replacing both the audio and cruise controls:
http://g35driver.com/forums/body-interior-...3-04-coupe.html
I presume it would be a similar procedure for the M35.
tis exactly the same.
as for cruise control $900 fitted in any state. the unit will be sent to a workshop for fitting. buttons fit ON THE WHEEL.
as for fitting the buttons it to ANY cruise unit - nup! this is a custom unit I had done and I market it as such. buttons are NOT stock either.
Pics please
here you go:
UNIT
buttons in place.
from memory this was a M35 stagea that I used for the photo. the radio controls are a by product of the cruise. if you have the integrated 6 CD unit then they will simply work.
Edited by Chris Rogers
ok I'll post a link up. my IP lockout thing must be in play. I can see the images and I forget that everyone else cannot.
click this:
http://www.audioexpress.com.au/site/index....rt&Itemid=1
Chris,
Can you also modify the cruise control / audio control to lit up the steering wheel?
So at night, they can be seen?
Like this DIY on the G35Driver.com?
the later G35 WAS lit. the button set was different and had a lighting feed INTO the column. they light up green. in that case he swapped them out for the later items. nothing new there. and to be honest - not worth it. the lights are fairly dull in comparison to the dash lighting. I CAN get those switches but they are TWICE as expensive as the ones I currently use.
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
    • Meh, At 60 years old, I have been doing dumb stuff for much longer than you mate, I am the true King And unfortunately I cannot be a maroon, as I am not brownish red As for not getting ITB's, the plenum intake will apparently show typical gains across the board and increase induction noise a bit, but, have all over less dort than ITB's Cost difference for the extra ITB dorts was significant though, the total parts for the plenum set up is "around" $2kAUD plus shipping, the ITB's were $4kAUD plus shipping, I was contemplating really hard about paying the extra $2k for all of the dorts, but weirdly, some form of common sense, from listening to the platform experts prevailed  As for the NA mod hate by some, I've had a few boosted cars, with all their inherent issues, I'm now looking at simplicity and legalities for a street car, maybe I'm just getting old, and I'm quite happy to spend some of the kids inheritance, 5kw at a time 🤣 And think of all the money I'll be saving on consumables that something with boost needs, like engines, gearboxes, diffs, clutches,  tilt trays... etc. etc. etc. 🤪
    • Haha.  I wouldn't say I am either but I've definitely been around it plenty.  I'm guessing you know the dial in is basically to make a handicap to level the playing field between racers.  The car with the slower dial in goes first and in theory if they run their dial in time and the faster car also does then they cross the finish time if they also have exactly the same reaction time - if you go faster than the dial in them you lose, but if you are too slow there's a good chance the other person will get to the finish line first. I'm normally supporting other cars but they were all pretty dialled and were egging me on to race as well, here's one of the cars I tune (Starlet) which ran within like 1 hundredth of its dial in through the competition: https://www.youtube.com/watch?v=inEBu-d9Gn4&t=69s
    • Where ever the fuel reg gets it reference is what I use to T into for map reference been a very long time so where it goes to plenum/runners I have no idea but never had issues.
    • What ecu? Same shop every time? Same ambient temperature? If timing is correct then pull plugs and see if lean or rich. Dyno can also read different if they have changed ramp rate or not set tacho/speed properly
