Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
well it probably looks worse than it is. it is dead square with the rad suport pannel.
that spot is where the GTR trust and HKS oil cooler kits are mounted also as there is no room in the right hand side.
and im putting a duct directly onto it so that should help also.
thanks for the query thoe. other peoples perspectives are always handy.
Are you running a thermostat or different PS oil with the cooler Damo?
Edited by XRATED
  • 3 weeks later...
nope just as normal.
I just bypassed my hicas solinoids and run the rear pump through the stock power steering/hicas oil cooler loop in the front....
The hicas soliniods are heavy!
Any updates damo? Still heading to the symonds gymkhana?
Cheers
Justin
  • 3 weeks later...
thought i best do a quick update. this time of year is hell for me so very little time sent on my car.
parts ariving
box opened
motivation growing
test fitting for the fun of it.
ive gathered the 3 1/2 inch stainless bends needed to make the dump and have been getting everything ready to go back together.
New deadline is a week before powercruise. chuck in xmas and new years and ive got about 3 weeks fee to complete it.
update
adapter plate and first part of the plenum bolted up ready to go on. all going well this time tomorow the head will be in place and everything will start to happen
ive been tidying things up and painting bits and bobs ready to be put back on the car like this cusco master cylender stopper that used to be blue.
ive finaly given the car pride of place in the shed ready to be attacked from every angle. and destickered it on one side.
i decided i wont have time to build a full exhaust the way i wanted so i brought a twin 2 3/4" system that i will still have to modify but should save me some time. ill also be keeping the rear mufflers as id like the sound level to be resinable. especialy for my nebours sake with late night loading sessions.
ive also gathered most of the speed flow fitting to plumb up the turbo. and am getting a fitting welded to the fuel rail for my fuel pressure sender to tidy up some more lines.
Ok so i got the head on during the week. no exciting pics there.
i braced up the exhaust manifold thismorning as out of all my friends cheap manifolds the only one not to have cracked yet is the only one that had any sort of bracing between the main flange and the turbo flange. then i bolted the manifold up to the engine. because the manifold was origanly for a t4 turbo it had an adapter plat to t3 but was missing the bolts so i got some cap bolts during the week and machined them down to fit at work. the last bit i got done today was the test fitting the turbo to see how the dump pipe will fit.
during the weekend i went and brought some bits off an ex-skyline owner. its funny how people acumulate heaps of shit out of skylines. the bloke had boxes of stuff he no longer needed. it was very temptiong to take it all but in the end i walked away with an old nardi wheel. a stock airbox as they are getting harder to come by and a spare boot lid so i can run multiple wing options. when i got the wing home i noticed that it has some very JDM rare stickers on it.
i was stocked as i had only recently been reading up about the R32 GTR touring cars.
  • 3 weeks later...
No updates for me but i am after some readers help
does anyone have any good pictures of r32s with side pipes. im after r32s mainly but r33 34s would eb good also. im trying to come up with a good designe for a side pipe for low cars.
Out the passenger door!
Have a look at russ's build thread for they're black r34gtr (hi-octane 34) for an awsome side pipe!
i've already sudjested the tunnel in the floor, and the door pipe. i doubt cams would let you run a door pipe, and i think his passengrs would sook
seeing as he doesnt have any ABS why not just go 90 degrees off the back of the turbo out the side of the front guard?
the only other way to get one on a low car that comes to mind would be to get some 4" or 5" pipe and have it crushed to its an oval shape for extra ground clearance where it passes under the chasis rail. (assuming you dont want to cut and reinforce it)
Well fk it all and turn the dump pipe upside down... run it right out the bonnet! H a ha ha.
also sudjested that one too :P
How about bolting a truck stack to the passenger guard?
Hot rod (cobra style) shrouded side pipes instead of side skirts?
Under the car, into the cabin behind the passenger seat, out through the rear guard behind the passenger door... Just build a box/heat shield over it in the cabin.
J.
all good ideas. just trying to find the right one. most of the problem is complying within the cams rules.
i realy need some pics as i think i know how to do it i just need an idea of how it should look on the outside.
i also didnt realise that mark and russes car had many detailed pics. i will go for a hunt.
just copy the super taxis. put a few, smaller diameter pipes in under the chassis rail. I'm going to run twin 60mm, same as my dump pipes. I have run 3" sidepipe before but it did scrape at times
i had thought that to but wondered weather 3 or 4 or 6 pipes would look gay/ try hard.
the biggest concern if i run side pipes is the potential for damage to the turbo and turbo manifold as a result of hitting them at any speed and at odd angles. ive flown backwards off the track more times than i care to count at over 120km/h trying to enter sideways at my local track.
which is why i suggested a semi crushed 4-5" pipe. if you are really worried, make up a bash plate for it.
yeah it's not easy to make a sidepipe for a 32 with any kind of sane ground clearance. mark and russ's 32 had the conventional just out the side pipe on the passenger side but it was pretty low. for marks car he cut the passenger floor and made a nice tunnel for it so it comes out level with the sills out through the side skirts. short of doing that to tuck it up in the body it's not easy.
the auto gallery R32 in japan runs one out the door. I have seen it up close and it's quite cleverly done. some pics:
autogallery%20rs6.jpg?__SQUARESPACE_CACHEVERSION=1289646946849
autogallery%20gtr%202.jpg?__SQUARESPACE_CACHEVERSION=1289639495793
thanks Barron. i i had to pick my fav 32 it would be this one. im loving the small bits that get changed from time to time.
that seems to be the easyest way to do it. thanks rob.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
