Damo's R32 Gts-r, On Going Project Fun Car. History And Use Full Info
funnely enough my uncles new super sedan engine lasted 2 laps on boxing day.... it was machined by the same people....as was my old head which failed
Well it doesn't really matter unless your going to use a northern Tasmanian machinist. I'm not keen to bad mouth anyone I just won't use again
  • 3 weeks later...
I've been slowly rebuilding the engine myself this time around with some helpfully hints from others. I mean of you have a book in front of you and some people to assist if things don't seem right than its like anything elce really.
Sunday's last job was to pull apart the oil pump and clean it. Well there was a surprising amount of piston bits that had been through the oil pump gears. It was then decided that I would replace the gears with another standard rb20/25 set. Tonight i pulled apart a rb20 pump. First thing I noticed was the gear shape was different. Then the thickness of the gears was also different. A quick look through some other bits and I found that I had stumbled apon a n1 oil pump.
This pump was pulled out of a box of engine parts I had brought years ago for a small amount of cash and fitted to the engine last time I had it built as it seemed newer than the original.
The big question I have for anyone that has ever pulled down a neo engine is. Do neo rb25s have n1 pumps? As all my bits were supposed to be neo engine bits.
Someone said recently in a thread I was posting in that Neos do indeed run N1 pumps standard. FAST says they use the normal pump but they may have changed during production run etc...
  • 1 month later...
I literally haven't touched this car for a good 5 weeks. The oil pump pull apart was the last job i had done and it's been staring me down every time I walked into the shed. I vow to never attempt to build/ major works on my own car over the summer period again. My work load and social life double in the short but sweet tassie summer. I am looking forward to long nights in the heated shed over winter when there simply isn't anything better to do.
So with 5 minutes notice I told Ben we were assembling an engine and that's what we did Sunday arvo. The bottom end is now complete. Waiting in a hg as i ordered the wrong one in a moment of dumb then the head can go back on.
Some extra bits I've picked up over the past 5 weeks are arp head studs, nismo adj fpr, r33 gtr dash cluster, gktech offset rack spacers and long hollow wheel nuts and a stack of pro flow fittings to plumb the boost controller nicer.
Things i have done on the side are. Repair exhaust manifold cracks. Make new brake line. And modify inlet side of the gtr throttles. Some pics of all of this to come.
some pic time
GKTech long hollow wheel nuts
all engine bay wiring excluding engine harness and oil pressure line through these neat gland nuts where the speedo cable hole once was
brake booster delete plate with modified brake lines
some mods to GTR throttles in this pic i have shaved off any unnecessary mounts and tapped a hole for a vacume feed to the fuel pressure reg.
and lastly for tonight semi completed engine
Engine in tuesday night after a small issue with box and engine alignment. The last 2 box jobs I have done have taught me a lot. I've obviously had lunch on my side the numerous times before.
Bens head back on and some minor plumbing done on my engine tonight. If nothing less the engine bay should look show worthy.
Yeh engine out time gives you a good opportunity to fix annoyting things. But deadlines and economics always make you stop short of all the things you would like to do
Isn't that the truth!
Were you logging AFR's when your injectors were failing? Because we have noticed issues with the Bosch injectors in our race car also. It seems over time the alcohol swells the rubber seat inside the injector and they gradually lean themselves out. Its possible your injectors may have been flowing closely when you got them, but this issue presented and left them partially stuffed and now they flow out of spec.
  • 1 month later...
Quick update
got car running last minute as usual. got it going last thursday night. while loading it on the trailer to go to dyno friday morning realised the brakes were stuck on due to incorrect adjustment of my brake pedal after making a booster delete plate. car got dynoed with brakes locked on. f**ked pads, calipers and split brake lines.
off to local brake place friday lunch. new lines calipers pads and full system bleed. got to track saturday morning. was pretty sketchy. ended up hitting a concrete wall after a few runs . fixed suspension and continued driving. sucked at batteling and got knocked out of top 16 but after setting into the car mid afternoon i won the extreme entry comp being 15km faster than second place.
no positive dyno result due to brake issue. and to add to that the car still has a fuel supply issue that i am working through now ready for another weekends racing.
but on a plus note the majority of the panel beating was fixed today so im not sad about it being bent any more. thanks to Grunt life's quick response.
  • Like 1
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
