Hey buddy,
That pc is a bit outdated so finding info about the specs is a bit hard. Hopefully you can help out.
1 x 80gb HDD
1 x 200gb HDD (pretty sure it's SATA)
Are both of them SATA? What's the brand(s) and had any problems?
Radeon X850XT
Is this AGP or PCI-e? Also, how many mb of memory?
Blue Thermaltake Xaser V case with something like 5 built in fans and fan control/temp monitor
Does the fan control/temp monitor work perfectly?
I noticed in one of your pictures the power supply was an Antec. What model is it? How many watts? And how old is it?
EDIT: Could you tell me the model number of the motherboard too? Thanks
Also, where are you located?
Thanks :P
Edited by TheMirror
https://www.sau.com.au/forums/topic/308941-gamer-pc/page/5/#findComment-5525570
  • Replies 91
Hey buddy,
Thanks :D
Sorry just saw this post now...Best to PM me so I see it quicker
1. Only the 200gb is SATA, The brand is Western Digital (Model number - WD2000JS-98MHB0)
The 80gb is Western Digital as well (Model number - WD800JB-00ETA0)
Never had an issue with either of them..
2.The video card is PCI-E and 256mb DDR3
3.Fan controller works fine. From memory I disconnected one of fan speed sensors because one of the fans wasn't compatible with the sensor or something and obviously the controller thought the fan was stopped, which it wasn't.
4.The power supply is an Antec True 480 (480W). Can't remember how old it is, but it's newer than the rest of the computer because my old one died so I replaced it with the Antec...
5.Motherboard is a Gigabyte GA-K8NF-9
6. I'm located in Hoppers Crossing, western suburbs of Melbourne...
Think that's all of em...Like I said if there's anything else you want to know, it's best to PM me for a faster reply :)
https://www.sau.com.au/forums/topic/308941-gamer-pc/page/5/#findComment-5535494
  • 4 weeks later...
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
