Remember OPINION isn't FACT...
There are part numbers on the picture of the core so why dont you check facts rather than voicing opinions. Facts with cause me the all the issues not opinions once they go on my engine
  • Replies 122
haha I have no idea why some guys are saying they aren't 2835s?? They seem to be guessing based on one known set of 2835 with different housings. Definitely NOT 2530, or 25 anything. The rear wheel is 10 blade with pitch that looks EXACTLY like a GT30 based wheel - although cropped to 56mm.
Which is what a 2835 is. These just appear to have different housing - perhaps earlier (or later) models?
Remember OPINION isn't FACT... There are part numbers on the picture of the core so why dont you check facts rather than voicing opinions. Facts with cause me the all the issues not opinions once they go on my engine
I trust you aren't talking to me with this rant? I'm helping you out here.
Cause all I've given you is facts, my only opinions such as I've given previously eg. "looks like" are stated like that because of my uncertainly of YOUR measurements.
I'm in the business of measurements and I see people FARK up all the time. You'd be amazed how much an effect preconceptions and subjectivity can have on objective measurements. ie. FACTS aren't always facts.
You measured the wheels both exducer and inducer - if the measurements are the same as 2835's - the link I gave you with FACTS. Actually measurements to within 0.1mm.
Then count the blades on the rear = 10 (25 series have 9 blades)
Then see that they are badged at 2835. Now nothing is certain in this world, not even Newtonian physics, but I'd be pretty damn sure they are 2835. Even if they aren't the blade charaterisctics of size, pitch and number of blades ensures they will behave like a 2835.....unless they are Chinese copies made from balsa wood.
Wow not sure why so many people don't believe they are 2835's I am positive they are, I have seen these turbo's before though they were made in limited numbers. I am sure they flow less than GT-RS. HKS rated them at like 760hp so between 2540 & GT-RS on a 26 you wont see any boost till 4500rpm.
On the right motor (rb30/26) they would be fine for street/track.
Reading through all posts I think most had never heard of the low mount 2835 kit hence assumptions were made. Others just tried to enforce an opinion based on the persons profile status, anyway no harm no foul. OP don't take offence bud there is some good advice offered here, if you need to spend more money to get these operational than a better performing (brand new turbo) why would you?
So how will these perform. Iv got a built bottom stock top? Iv been in a gtrs equipped car and it was laggy as shit. But gave a decent wack
They will be very laggy, being as they need a lot of money to get going you would be better off buying a set of working -5s, you will make similar power as you probably won't be able to push the 2835s that hard where as the -5s will come on sooner with less lag. They also won't need new piping etc like going a single will.
I would say you have it there mate "laggy as shit" you need head work (porting)and cams to be able to live with them on the street. The GT-RS has a smaller zorst wheel so may be more responsive than these but are rated higher hp from HKS. That would give a good indication as to why these were never made in large quantity's.
Not to bad. Mid 300's i seemed to see a bit of. Is that their flow limit? What the max ppl have gotten out of them?
400s, and they will look and fit much nicer than a big single, I think they will suit your goal better than anything else, also quite well priced.
Edited by Rolls
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
