  • Replies 122
Iv found a daily driven car that's also used on track running a bigger version 0.73ar as mind are 0.64 or 0.61 can't remember that's running hks 272 with 10.5mm lift with springs retainers and seats. And ported head. Although its making 720hp..
Full boost around 6000rpm sounds about right, which means you'll need to change each gear at over 8000rpm to keep on boost.
I'd stick with mild cams ~270° max, with moderate lift. High lift and duration cams are harder on the valve train. The large turbos will extend the top end significantly anyway. Just focus on getting a lighter and stronger reciprocating mass. Get some strong and light pistons, rods, nice bearings and get the crank checked. Probably look at a dry sump setup.
Can't see a stock RB26 holding onto those revs at high boost for long, especially on a track.
As per the above post, given the fact that your power band will be moved up between 6,000 and 8,000+ rpm.
I am running 272 deg cams at 10.5 mm lift and these are probably not enough to support such high rpm operation. Their efficiency range is much lower rpm, probably coming on at between 3 and 4000 rpm, which is suited to my longer-stroke, slower revving 3.1 and smaller turbos. Yes going bigger with cams means more doughy down bottom - it will be slower off boost than a VL commodore - but for that size turbo you are optimising for high RPM operation. I think the above suggestion about 280 deg would be the minimum, as you will need big duration to maintain 'acceptable' ramp angles.
And your mum probably won't be impressed if you throw her the keys to drive it down to the shops, as per your thread about the turbos, but that's a given for this setup.
Decided to ditch these and start on building a new engine.
Your engine is more than likely capable of high 300s if you choose the appropriate turbo. Shouldn't need to rebuild it, what turbo are you thinking of replacing it with?
At the moment looking into building a stroker engine. I know the obvious for streetability and response the choice for turbo are twin bolt ons and they will punch out the numbers i want but as iv said somewhere iv always wanted a single turbo 26. I thought people are getting decent results from mid sized singles these days?
My personal preference is for a single, tricky to match or better a good twin setup but definately possible.
That said is it your 2835's on ebay atm?... i think i need them, whether or not i win them is another story :P
Na they aren't yet mate. They'll be up soon tho. Do you want me to let you know when they are?
i'll keep an eye out, set my ebay snipe for the pair on there now so we will see how it goes.
With the stroker my brother who's a mechanic is gonna help do all the non critical rb26 stuff. He isn't in a performance scene but is full of knowledge when it comes to all mechanical stuff. And has put me onto an engineering shop in addl who's build some of adel hardest gtr's
Guest
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
