  • Replies 122
No probs mate. Sorry i took some of my replies over the top.
Can we get back to the original topic?
If i decide to keep these, what area of cams would best suit them?
I guess my 3 options 1. Got them here and try make the most out of these. 2. Sell off and buy what was suggested or 3. Sell off and buy a single kit..
But can we stick to the topic at the moment. About te best bump stick for this set up?
What do these compare to the -10 turbos??
They would be similar but the -10's would be more efficient & produce better hp. My advice to use these on your block get some 270 cams with a lift of min 10.25 you spend money on a port job I suspect you could improve spool by 500rpm. You will need to spin the engine to 9k to get the most from these.
Dunno if i wanna go to full on on this engine. As we are thinking of building another engine up. Which would better suit these. Would these suit other engines as single? Like sr and rb 20and 25's??
Do you suffer from ADD? you have been told 10-20 times
SELL THE 2835s! not one single person EVER has said keep them, every single person has said SELL THEM
BUY -5s and build a stroker.
Once again not a single person has said go a SINGLE especially not a T04z, EVERYONE said don't use a T04z, get twins that look stock, are your cheapest option, and build a 3L rb30, also your cheapest option if you are building a motor.
end of story, stop asking the same questions and READ what has been said MULTIPLE times. If they are laggy on an rb26s they will be even laggier on an sr20,rb20,rb25, they are all smaller capacity, you do realise that capacity is one of the major factors influencing spool on a turbo yes?
Sorry I lost my patience, but there is only so much I can read. Please do us all a favour and re read this thread 2 times, every single post, twice, all your questions have been answered.
Edited by Rolls
sell, purchase GT2860-5 and drop in tomei cams, plus some cam gear pulley wheels, for under $3500 total.
Tomei procams, in/ex 270, 10.25 lift, $825 delivered for the pair - http://www.ebay.com.au/itm/Tomei-procam-camshaft-skyline-rb26-det-r34gtr-in-ex-270-/140424051691?pt=AU_Car_Parts_Accessories&hash=item20b1ecfbeb
garret GT2860-5, pair $2500 delivered, http://www.ebay.com.au/itm/GARRETT-GT2860R-5-x2-TURBO-KIT-Nissan-skyline-rb26-det-/140420140354?pt=AU_Car_Parts_Accessories&hash=item20b1b14d42
Im using basic 'no-name' brand camgear wheels in my Rb26, with Greddy street-special camshafts to suit R34 GTR (using R34 CAS), 87mm CP pistons, ported head including HKS cam springs, built bottom end for track including HKS oil pump, sump/head baffles, oil-return, Power-fc with 550cc injectors, etc. Turbo's in my case are the downfall, using stock turbos highflowed with steel wheels. Engine built to be capable of over 350rwkw, turbo's only capable of pushing the engine to perhaps a max 300rwkw. One day will upgrade to GT2860-7's. Currently response is simply awesome, with loads of torque. Running-in tune only atm.
I seriously suggest James that you match the turbo's to the engine. Too large (as is the case I feel with your 2835's) and you wont be happy with the end result. Slightly on the smaller side and you'll be very well pleased with the repsonse of the entire package. For the street -5's would be on the large side but capable of 400rwkw, -7's would be perfect and capable of up to 350rwkw.
Some interesting info. I'm just gonna sell them off and build something else. I met and had a good talk to someone that was a proprietor of a shop in adelaide most drift cars. But had some good input for me and said he'd be happy to answer/help out with anything.
Guest
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
