Hi
am about to start shopping for a GTR this weekend :(
I understand GTR's come with T28 turbo's but not all models are ball bearing units.
Can anyone pls shed which which year models had the old school T28's and which ones came with the ball bearing versions of the T28?
Also, what sort of "flaws" should I look out for or common faults with the R33 models?
Any advice would be much appreciated.
Thanks and Happy New Year all.
- M
https://www.sau.com.au/forums/topic/30897-which-turbos-on-r33-gtr/
Hi 8thSIN,
all I can say is "Good Luck" in finding a half decent GTR. The only thing I would reccomend is getting it checked out by "Someone who really knows" not just someone who thinks they know.
By the way, I think Gerald from ICE Performance is selling his Series 1 GTR Vspec.
Hi
am about to start shopping for a GTR this weekend :P
- M
I was of the opinion that 33GTR's came with the same ceramic bb turbos. The exception is the n1's which have steel wheel n1 turbos.
As for flaws, well the early 33's have been around for a while. Things like the rubber hoses & pipes in the engine bay get frail and brittle due to heat and age, as well i have seen AFM's become faulty and lean out one bank. Coils can become faulty as well as fuel pumps. Origional kilometers also becomes a problem as the japs love to wind back the clock. Remember this can happen to any and all cars that are becomming older. I dont think there is too many common flaws though, just basic maintenance and attention is required.
Gerald from ICE Performance has an absolute immaculate R33 GTR for sale. This was/is his personal car and is a real stunner. If you are serious about finding a good car at a great price call him on 9512-7591 or 0414-359-888
thanks RedR32. I was under the impression that some early model GTR's (maybe R32's??) came with non-bb turbo's then the later models were updated with ball bearing units. I know that the R32 GTS-T's came with ceramic wheels instead of steel making them frail with anything over 13-14psi.
pity about the "winding back the clock" issue.. yeh I know it's one of their favourite past times, but I hope in finding a late model GTR, it might be more "believable".
Call Gerald. Its midnight purple, stock (except for exhaust) origional kilometers and never crashed. That is guaranteed. Just take it for a spin and you will see im right
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
