  • Replies 55
Actually, that makes me think of something.
Matt, to get more "pop" in your photos, either bump up the saturation in Post-Processing of the photos, and/or try taking the car to an environment with more contrasting colours. Because your car is a light silver colour, you need to find a background with more colour than "concrete grey" - even if some of the pylons are painted in more colours, it could just be enough...
That's what I was saying, that's right. =)
NEW!!!!!!!!!!
>[img
[/img]
I'm pretty sure I can see an improvement already :) Thoughts?
That's the way you do it. Right like that.
Keep these coming and you will be golden.
Also, that one off-angle shot works fine, but don't get carried away with those because people just flat out don't like that perspective as well.
Great job over all though, really.
Edited by AKW
THanks for the name change slimmy wimmy!
Hey Tristian! Yeah i got a new number ages ago. I'm still on here if you want to flirt with me though. How's the beast going???
More pics of random things. I'll start with some motormomobiles and see what else goes on.
Smart Roaster
Australias best Starlet GT
Ninja (sitting on a ninja)
the first one of the river one is win! great colours!
dude, 32 went awesome until around september 09! bad news is i got hit in the rear while i was stationary by a douche and she was written off - pretty f**king gay :(
i tried msging you a few times (after i got an rb25 turbz, n a few other itmes) - and yeh figured you'd died :) good to see the evo looks mint and your gf still has the GT!
sooo yeh now ive got a 180, which infact ive just packed up ready for the drift day tomorrow :/
catchya man!
Here is a lunch time attempt at trying to miniaturise a caravan park for lego people. This was using an old pic from a crap camera in crapper conditions, so it doesn't have the quality needed. Anyway.. figured i need to start somewhere.
Nice Tiltshift Matt :cool: have you tried having the focused area focus from left to right heading up a bit instead of straight across and on the grass, try making it
umm.. like... this. http://img251.imageshack.us/img251/7895/caravantoys.jpg
I hadn't but looking at the line I can see why it would probably be more dynamic if I had.
I might give it a quick bash like that tomorrow to compare, Or I'll try my hand at another pic if I can find something suitable but better quality.
cheers African American :P
I really need to learn how to use a flash.
I've managed to source an old speedflash for the right price (FREE) and I've been trying to work out how to use it. I've been out a couple times trying different things. If you've got any tips feel free to drop me a line :happy:
Anyway, I took this one last night out the back of Castlereagh, near the regatta centre, which is right at the base of the Blue Mountains. The camera is facing Sydney which gives that great light transition if you can get out far enough to where the skys are still dark.
I'll probably clean it up in photoshop tonight, and i plan on going out to the same spot and reshooting at a later date when I'm not totaly retarded with using a flash.
CC welcome
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
