To Spray Or Paint
DIOR 33
 Share
Hi everyone my front bar is all fixed now actually has been for about a month now and i dont want to put it on till its painted
my best mate is ment to paint it but it obviously hasnt happened
i know i can buy spray cans from autobarn to my paint code but how much of a difference will it be from spraying it from a can to a spray gun and obviously get someone who knows what they are doing
Ta
xx
Kellie, if you can get the paint matched (exact paint code) for your car, I've got spray painting equipment here (and I use to be a spray painter by trade). I'm doing my front bar the first weekend in March. Can fit yours in too if its simply a spray paint, no prep/sanding. I'll have some clear to go over the top too left over.
Keep in mind tho I'll be in my garage ... no spray booth or baking oven. I've sprayed all my bikes (GSXR and TLR) so you've seen the quality of my work.
:D
I'll do it for you seeing as you're a good mate. I don't do private jobs anymore ... so no one else need enquire. Sorry.
:) roo have i ever told you that i love you so much :) thankyou but i also cant get something for nothing you know i dont like doing that so there for ill bring the JACKS :)
also there is no priming or sanding to be done all is good Ricky did that for me when he re glassed it
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
