Hi everyone my front bar is all fixed now actually has been for about a month now and i dont want to put it on till its painted
my best mate is ment to paint it but it obviously hasnt happened
i know i can buy spray cans from autobarn to my paint code but how much of a difference will it be from spraying it from a can to a spray gun and obviously get someone who knows what they are doing
Ta
xx
https://www.sau.com.au/forums/topic/308976-to-spray-or-paint/
Kellie, if you can get the paint matched (exact paint code) for your car, I've got spray painting equipment here (and I use to be a spray painter by trade). I'm doing my front bar the first weekend in March. Can fit yours in too if its simply a spray paint, no prep/sanding. I'll have some clear to go over the top too left over.
Keep in mind tho I'll be in my garage ... no spray booth or baking oven. I've sprayed all my bikes (GSXR and TLR) so you've seen the quality of my work.
:D
I'll do it for you seeing as you're a good mate. I don't do private jobs anymore ... so no one else need enquire. Sorry.
:) roo have i ever told you that i love you so much :) thankyou but i also cant get something for nothing you know i dont like doing that so there for ill bring the JACKS :)
also there is no priming or sanding to be done all is good Ricky did that for me when he re glassed it
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
