96 R33 Gts-t Series 2 Silver
Car is located on northern beaches syd, NSW. i live in lower nth shore so pick up welcome or post at buyers expense.
due to a tabletop truck hitting my rear driver qtr panel i have decided to strip down the whole car and sell off all the bits, so for sale i have:
complete RB25DET engine 125,000 stock engine never been opened inc os giken twinplate clutch worth $2,000
$2800 (and ill throw in fmic with pipes) ps. 100k service done with water pump and hks belt among other bits and new alternator
5sp Gearbox
$1000
Apexi Power FC Inc hand control, tuned @ 220.8 rwkw (fmic, full exhaust, 12psi, pod filte and gtr pump) tune worth $400
$900
Greddy/Trust coilovers type S
$1200
nismo 555cc injectors brand new never used
$150ea or $800 for all
Tomei gtr fuel pump
$200
spitfire coils
$300
Apexi Pod filter
$50
Apexi turbo timer with loom
$100
Left & Right Headlights in excellent condition Inc 6000k HID conversion
$500
Turbosmart boost Tap (black stealth series)
$50
genuine rear strut brace
$offers
front strut brace inc master cylinder brace (polished alloy)
$150
Front and Rear Seats immaculate condition
$offers
Dash surround (upper&lower) complete with clock & vents and momo black leather boot (no marks or holes on panels)
$150
genuine floor mats 5 piece
$offers
Alpine Headunit 9886i on brackets with pocket inc nissan loom adapter and ipod cable (plug and screw straight in)
$300
hks inlet and exhaust cam gears in box never used
$400 for both
genuine greddy inlet plenum never used with instructions in jap all fitting hoses and clamps still in plastic
(i have started sanding the manifold so its a unfinished project sell as is)
$700
greddy twin pillar mount gauge thingo with str black face electrical boost and oil temp gauge's cost me 600
$350
used Q45 afm
$150
stock afm
$100
stainless 3'' 1 piece turbo-cat dump pipe
$200
3" Highflow cat
$120
i also have open to offers:
Bonnet,
Grill,
boot lid x2 with wing,
doors with trims
front & rear(inc wiper motor) windows,
left tail light,
front bumper(blinker&fog lights inc),
front left n right guards inc blinkers
19'' wheels hp design
diff and or rear cradle
brake setup (non abs)
roof with factory sun roof
instrument cluster (125,000ish km)
parcel shelf
floor carpet immaculate
passenger air bag
steering wheel (no wear marks)
number plates white on blue WLD25L only 130yr extra for rego NSW only
passenger qtr glass
dash
glove box
kick panels
scuff plates
inner qtr trims
climate control thingo
standard ecu
standard fuel pump
standard fmic
rear boot garnish
m spec side skirts
Before i sell most of the running gear i need the engine gone first so i can move the car sorry for
if you have any questions call me (paul) on 0414600083 between 8am-10pm 7days, ill try and get some pics up asap!
  • Replies 50
 Share
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
