96 R33 Gts-t Series 2 Silver
  • Replies 50
As stated in an earlier post:
THE CAR HAS BEEN SOLD!!! it sold complete with every single standard part!
This is all i have left for sale:
Greddy/Trust coilovers type S
$1200
nismo 555cc injectors brand new never used
$150ea
Apexi Pod filter
$50
Alpine Headunit 9886i on brackets with pocket inc nissan loom adapter and ipod cable (plug and screw straight in)
$300
hks inlet and exhaust cam gears in box never used
$400 for both
greddy twin pillar mount gauge thingo with str black face electrical boost and oil temp gauge's cost me 600
$350
used Q45 afm
$80
cheers
Car is located on northern beaches syd, NSW. i live in lower nth shore so pick up welcome or post at buyers expense.
due to a tabletop truck hitting my rear driver qtr panel i have decided to strip down the whole car and sell off all the bits, so for sale i have:
complete RB25DET engine 125,000 stock engine never been opened inc os giken twinplate clutch worth $2,000
$2800 (and ill throw in fmic with pipes) ps. 100k service done with water pump and hks belt among other bits and new alternator
5sp Gearbox
$1000
Apexi Power FC Inc hand control, tuned @ 220.8 rwkw (fmic, full exhaust, 12psi, pod filte and gtr pump) tune worth $400
$900
$1200
$150ea or $800 for all
Tomei gtr fuel pump
$200
spitfire coils
$300
Apexi Pod filter
$50
Apexi turbo timer with loom
$100
Left & Right Headlights in excellent condition Inc 6000k HID conversion
$500
Turbosmart boost Tap (black stealth series)
$50
genuine rear strut brace
$offers
front strut brace inc master cylinder brace (polished alloy)
$150
Front and Rear Seats immaculate condition
$offers
Dash surround (upper&lower) complete with clock & vents and momo black leather boot (no marks or holes on panels)
$150
genuine floor mats 5 piece
$offers
$300
$400 for both
genuine greddy inlet plenum never used with instructions in jap all fitting hoses and clamps still in plastic
(i have started sanding the manifold so its a unfinished project sell as is)
$700
$350
used Q45 afm
$150
stock afm
$100
stainless 3'' 1 piece turbo-cat dump pipe
$200
3" Highflow cat
$120
i also have open to offers:
Bonnet,
Grill,
boot lid x2 with wing,
doors with trims
front & rear(inc wiper motor) windows,
left tail light,
front bumper(blinker&fog lights inc),
front left n right guards inc blinkers
19'' wheels hp design
diff and or rear cradle
brake setup (non abs)
roof with factory sun roof
instrument cluster (125,000ish km)
parcel shelf
floor carpet immaculate
passenger air bag
steering wheel (no wear marks)
number plates white on blue WLD25L only 130yr extra for rego NSW only
passenger qtr glass
dash
glove box
kick panels
scuff plates
inner qtr trims
climate control thingo
standard ecu
standard fuel pump
standard fmic
rear boot garnish
m spec side skirts
Before i sell most of the running gear i need the engine gone first so i can move the car sorry for
if you have any questions call me (paul) on 0414600083 between 8am-10pm 7days, ill try and get some pics up asap!
 Share
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
