Went Skydiving today... 14,000ft @ Nagambie (on the was to Shepp)
Wasn't too bad - nowhere near the rush i was expecting... So thinking about doing the solo course soonish.
ANYWAY, anyone interested in going up in the next couple of months??? Could organise a few of us to head up on a Sat etc etc.
I'll probably go another tandem again just to get a better feel for it now i know whats going on etc etc.
Overall it was great fun, such a weird sensation... :down:
https://www.sau.com.au/forums/topic/309005-skydiving/
ive driven past the signs which say skydiving when i drive to shepparton - always considered it - bit too scared though :) lol
grats on the jump! if i ever work up the balls to do it lol ill send you a message :)
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098249
Trust me when you see other parachuting down while your waiting it really makes you want to go. And seeing that no one plowed into the ground it also a plus lol. Mind you 14000 ft is above the clouds so you fall through them :D when you out there and already start falling any fear you have dissapears. It I'd an awesome sensation even though it really hurts your cheeks lol
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098355
We went for my birthday last month at Mission Beach north of Townsville QLD. Ment to be the best jump site in Aus because you can see the entire reef and coastline.
Ash if it wasn't the rush you were expecting you must have balls of steel! I thought it was insane!
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098752
oh hell no - i hated standign on top of the eureka towers - def aint going to jump off some plane with a dude strapped to my back....
and pay for it???? wtf!
Im with emsta on this one....
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098829
I did the mission beach jump too, 14,000ft. Did it on a clear day so could see the whole ocean and beach. Was awesome.
The day before I jumped i was watching others skydive. One of the jumpers parachute didnt deploy and roman candled. He had to deploy the 2nd parachute which is much smaller and they both landed with a thud on the beach haha
Didnt stop me from going on my jump the next day haha
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098836
Ye my best mate did a jump from there or maybe Rainbow... somewhere up that north way... view was tops.
Seriously not the rush i was expecting at all. In the plane on the way up i wasn't even getting jittery about it all which was strange lol.
I was like "oh f**k" for about the first 2 seconds as we were spinning around but after that it was all sweet :)
https://www.sau.com.au/forums/topic/309005-skydiving/#findComment-5098952
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
