Hey Troops,
I know this has most likely already been covered but I thought Id ask anyway.
I recently installed a Defi Gauge(AMBER/RED) on my steering collum and it makes the Stagea cluster look abit out of place.
got me thinking, Why did Nissan choose to have SO many different colours through out the Dash.
eg:
Cluster = Red + Amber/Yellow
Buttons = Blue/green Teal?
Auto selector = Candle light :down:
Climate controller / standard strero = White
I attempted replacing the cluster lighting with Red T5 LEDS but it only made "red circles" on the cards.
So I scrapped that idea. :D
Has anyone changed the lighting scheme of their S2 Stagea?
Cheers
Edited by JDM_Spirit
https://www.sau.com.au/forums/topic/309008-s2-dash-interior-lighting/
In correct. dans led kits work fine.
In series 2's? In the s2's the dash has some colour filter which stops blue or something rather and makes normal LEDS very dull. The centre console is easy to do, but the dash i'v never attempted.
All dash's are going to have some sort of colour filter built into them. So you must think about what colours will work behind what filters and then select what colour leds
Yeah, thats why I was going to make them RED, The needles are Red and The numbers have a yellow filter so I thought Id 'round them up' to just RED :D
My previous experience with Older imports Ie: R32s and S13s, the filters are 'white' so any applied colour works well :(
Yeah, thats why I was going to make them RED, The needles are Red and The numbers have a yellow filter so I thought Id 'round them up' to just RED :P
My previous experience with Older imports Ie: R32s and S13s, the filters are 'white' so any applied colour works well :)
Got red Leds in my S2 instruments, they look great, no dim spots. I can't tell you what make they are, since they were in the car when I bought it, but they are the type with 3 or 4 leds in each lamp.
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
