ok round 1 was a blast so time for the next one
Calder park, 13th March...that twilight as in racing in the evening/dark. not some boring ass movie
Entries - http://www.wrx.com.au/motorsport/Entry_For..._March_2010.pdf
Supp Regs - http://www.wrx.com.au/motorsport/Sup_Regs_..._March_2010.pdf
Entry List - http://www.wrx.com.au/forum/viewtopic.php?...4c3a5f9958df02a
2010 SAU Vic Track Motorsport Championship proudly sponsored by:-
https://www.sau.com.au/forums/topic/309034-calder-13th-march-twilight/
  • Replies 74
Matt, was that the same day you went 160km/h down the main straight in reverse?? :D
Go on Roy, DO IT!!!! 1:05's is flying though....
Interesting times on the lap records list.
Didn't know this list existed.
Might have to clear out the cob webs and give Aarons Calder record a go.
Been a loooooong time since I punched out a lap time....
LOL nah Jack, if I recall correctly this was on a nice warm 30 degrees day
Iam hoping to beat it.
Hehe, you can try! I'm thinking Adz or Ryan could... either way if someone goes faster I'll return next year to claim it back :( More competitors in rwd mod the better!
There's also a myth about a certain silver r32 gtst which no one has seen or heard of hitting the track for many years... could this be it's comeback? :wub:
In what car? are you working on a new car?
Unfortunately my friends decided to get married on that day. Pretty damn inconsiderate so I won't be driving. I've still not had a go at Calder :D
I think that list needs correcting.
For winton
Modified RWD Adam Newton R32 GTS-T 01:39.04 28/07/07
Standard RWD Adam Newton S15 01:33.264 18/07/2009
I think they are the other way around^^
For winton
Yeap that was me making a typo.
has already been corrected, AAron just has not had a chance to upload it yet.
Martin
Yeah my fastest lap at Calder was from the day Blaise was running around still in his WRX. I think that might even have been Jacks first track day and if I remember correctly he was lapping around the 1.15 mark. You got better mate! :thumbsup:
and I think Chris' time in the Volvo might still be better than anything he's managed in his GTR there.
Good - IF ITS DRY.
If there is any sign of wet then Calder isn't so good for Newbies (or even not so Newbies) as the VHT turns the straight into a slip'n'slide.
But it's not overly complicated so its ok for Newbies. just make sure your brakes are ok as there are some big stops at Calder.
LOL, I remember that day, an MX-5 went a second quicker than me.... and 11 seconds slower than you...
Wouldn't mine getting out there to see if I can better my 1:02.7.
What do u reckon Snowy? u up for it???
Guest
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
