hey ppl think my turbo is on its way out
was driving fine and then next time i put my foot down it screemed,
am i right in presuming the bearing is just about to give up on me,
i have reved the engine to 6k without getting on boost and there is no noise
then put my foot down started to boost fine then started screeming at about 4k might have been a touch earlier.
its done about 3 years at 12 pound since ive had it, with the odd burst at 1 bar. so done ok i spose
https://www.sau.com.au/forums/topic/309059-standard-turbo-screeming-at-me/
I'm assuming the sound of a failing turbo would be distinct. If you aren't sure, you could take it to a mechanic who specialises in installing turbos. I doubt boost leak. If it was a boost leak you would still get the spooling sounds, just no performance, or severely less performance.
Is it the ceramic turbo or have you had a stainless steel turbine put in it? You can buy stock R33 turbo's for a couple hundred dollars or have your one rebuilt for a little more and run it on more boost.
my FMIC had a leaky join (nothing a good norma clamp didn't fix) that sounded like the stock turbo was on the way out... but i eventually tracked it down to the FMIC area and got a couple $4 norma clamps, and redid all the joins/piping etc... pulled it apart, put it back together nice and tight and it was sweet.
It sounded nasty, and was like a high pitch scream kinda :D but was only a leak in the end and the turbo was 100% when we pulled it off and put a highflow on.
well those replies are very positive
i just had the intake pipe off and felt for shaft play, there seems to be none at all up down left right, but a little bit front and back but it wouldnt be more the a mm or so i reckon,
i also had a small magnet in there but couldnt get it stick to the front wheel although it did look like a steal wheel, but arent they a nylon wheel on the s2 r33??
i once got an intercooler setup done on a turbo NXR, i thought it had this new awesome induction noise! later i realised the massive high pitched scream was from the back 2 nuts on the turbo to manifold gasket my (former) mechanic had undone for a little extra revenue.
with the above mentioned topics, they are all fairly simple, give them a go. check all ur pipping, and if not buy a turbo and dump gasket and take the turbo off for inspection. if its rooted you will know when it comes off, and ull probably find its an easy job anyhow.
GL
You probably find sections of turbine wheel's missing. I've had this issue when I bought my R33 test car. Once that material is missing the turbo is out of balance. So at high RPMs the noise you heard is vibration through the shaft.
Well check gasket and cooler pipe leaks before pull the turbo apart. Could be some thing very simple.
id get someone who knows a fair bit to come have a look or just pull the turbo off. mine went last week it sounded like a cop siren! so i had a closer look checking all the above mentioned. after i pulled it off both wheels looked fine wasnt till i shone i tourch and stuck my head right up to it a piece from one of the impeller blades had chipped off, from the turbo spinning out of balance as mentioned above.
checked all the cooler pipes and vac lines, still noisy
looks like ill be pulling dump off to inspect the turbine wheel tomorrow. hoping for the best, expecting the worst
this will really put a dent in my 26 projecy
if the noise is a lous hissing, then i'd say its probably just a leak...
spray some soapy water or carby cleaner all over your intake side gaskets and see if it bubbles up anywhere...
ok so coated intake side with carby cleaner and couldnt see anything out of the ordinary,
pulled dump and front pipes off to have a good look at exhaust wheel, all is there and looks in good and no shaft play from that side either
however could this noise be coming from a leaking exhaust gasket, as i can see a little bit of oil leaking out of the bottom of it,
also best tool for bashing a cat??
is the car sluggish at all? or is there no loss of power?
to bash out my cat i used a strong metal rod, hammer, vice and over an hour of non stop bashing it. however im not using my gutted car nemore wanna buy it im in alexander heights ?
cant you run the car with the intake off to see if the sound is from the comp wheel? just try running it hold the revs high enough and try locate it properly no point guessing lolol if its internal try using a stethoscope on the parts u think the sound is coming from you will hear alot more clear if theres grinding etc..
i know the sounds =) my RB20 had this scream when coming on boost! turns out it was the gasket between the Turbo and the Exhaust manifold it had blown out.. and you couldnt really see it.. when looking for the problem i saw a little tag slightly hanging out when the gasket should have been. when i pulled the turbo off.. the gasket was f**ked! replaced it.. and all good! hope this helps!
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
    • I might have gone a little more South Efrican.  But this is off topic.   😍😍 FD 😍😍
