i have an 1994' r33 rb25det. i know this..
every time i get a roadworthy done or vic roads looks up my engine number it says its an r32 1998" model. when i purchased the car they said it was a 1998 model even tho i knew it was definitely a 1994 model.. im thinking this could be because it was inported in 1998 but what i dont understand why is it being called an r32? i know my cars not stolen because i had it roadworthy & registration done about 3 months ago and they do a background check.. any ideas?
https://www.sau.com.au/forums/topic/309063-what-is-my-car/
What colour is your compliance plate?
I'd say it is how it is complied. I've seen few Imports like this.
If there aren't any problems, I won't worry too much about this.
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5098294
nah i dont think its a 98' engine, its definitely an rb25det, most of it has been rebuilt within the last year so the car would of been imported with the standard engine. im guessing it probably is just a mix up just wanted to see if anyone else thought that.. maybe i can just go into vicroads and get the details changed on it? i just put my vin on the VIN thread but it kinda looks different to the others that are on there.
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5098651
it'd say it is possibly likely due to some dick filling in the initial compliance papers incorrectly.
+1
Sorry I wasn't actually suggesting your car is a 1998 model, your car looks like a s1 '94 to me... 98's were s2's and you have an s1 front bar so yeah... just pointing out that 33's were still made in that year. I think mad082 is on the right track.
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5099011
maybe i should hit the car yard up for false advertisement then, it was advertised as a 94' r33 4 door gts25/t rb25det, the nissan FAST program i have tells me its a 93' r33 4 door gts25/g rb25de, although i know its an rb25det engine not an rb25de+t because as soon as i took the turbo off it ran like a box of s*#t, whereas if i took a turbo off an rb25de+t it would pretty much just run like an N/A engine because the compression would be more or less normal.. anyway doesnt really bother me im selling it soon and building a new car with an rb26dett :cool:
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5100157
i got onto the x owner and he was telling me he's built the engine from ground up, its a new engine i was aware of that but i had thoughts that it was still the same make of engine before he rebuilt it (rb25det), but it is actually kind of a good thing, i have 8 months till im on my fulls and the compliance plate is calling it non turbo, even tho i have a run around for now its still reassuring that i can be a little less worried when i drive it :P
Edited by azzafreddy
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5101286
The year of a car is determined by it's first year of registration. For example, I used to have an r32 gts-t that was a 93 model but FAST listed it's 'build' date as November 92.
Likewise a friend bought a commodore at the start of last year which is listed as an '09 model but the car was 'built' in 2008.
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5102626
You can give us your chasis number, best look at the driver side back of the engine theres a plate thats says either HCR32 or ECR33, that 30 something is the name of the car plus dude change that ugly color yuck
https://www.sau.com.au/forums/topic/309063-what-is-my-car/#findComment-5105671
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
