Hi - Just by chance is any one on here a refrigeration mechanic or got a good 2nd hand full size fridge they want a few dollars for.
Mine stopped chillin on Friday night and the drinks are almost too warm to drink - almost!
Please PM or call 0404822143 if you can help me out. Thank you
Edited by Sinista32
https://www.sau.com.au/forums/topic/309067-not-chillin/
no idea how old the fridge is.. ive had it for roughly 2 years
Sinista32 gets first say, if he doesnt want it its all yours
NERM :cool: Thanks - got nothing at the moment so I need to say yes. Will PM you.
sorry giveway...
PAT - please check and let me know 0404822143
Thanks heaps :)
BTW - Ron the fridge mech said ditch mine :huh: very expensive to fix.
https://www.sau.com.au/forums/topic/309067-not-chillin/#findComment-5099875
Thanks Shell - yeah all food stuffs had to be tossed as well as everything in the freezer.
Yeah it was relatively newish but well out of warranty. Just buying food day by day ATM so thats ok. Just got a job so a new fridge is out of the question for a while.
Thanks for the offer :)
I checked allclassifieds. The only fridge at the moment becomes available on the 15th of March when the advertiser moves :ermm:
Edited by Sinista32
https://www.sau.com.au/forums/topic/309067-not-chillin/#findComment-5100790
i have a big fridge, the thermostat thing is kinda buggered, the freezer doesnt freez but the fridge does?/?//
its sitting there waiting for my back to recover, you are more than welcome to it!
it was going to be turned into a giant esky / bench seat out the back for bbq's etc.
https://www.sau.com.au/forums/topic/309067-not-chillin/#findComment-5101659
    • It's all about reducing the overall output. Reduce the source of it, you have wayyyy less to deal with in every other step and trick you play with. It's why something like a modern vehicle, so VW, Audi etc, there's thousands of tables for the ECU to calculate what it should be doing with the engine.   Why would you NOT reduce emissions the most effective way possible, when it has very minimal tradeoff, AND manufacturers are always struggling to meet the current standards.
    • Ran into this bloke trying to give Oscar some advice pre-race today.
    • Yeah I've personally seen the RB26 pull 30 degrees of ignition timing out of the base timing map if the ECU detects a cold start, it nearly starts misfiring because of it around 2000 rpm and it feels like the engine has no power. I'm just surprised that modern OEM control strategies are actually trading off efficiency for in-cylinder emissions. I would expect something like aggressive EGR dilution + tumble generation valve use to improve EGR tolerance to reduce in-cylinder NOx + HC from crevice volume while also reducing throttling loss vs pulling out some timing if not knock-limited.
    • *** DATE CHANGE *** Date has been changed to Saturday 17th May. The time and location is still the same!
    • You're more than welcome to - looking forward to meeting you!!  The turnout depends on the event and location... Pizza Runs on a clear night can drag out a decent crowd!
