GTR Parts suit 32/33:
r32 gtr diff perfect condition very low k's mech lsd $650.00
R33 gtr A lsd, perfect condition low k's $450.00
R33 gtr rear axles perfect condition $200.00
R32 gtr Rear alloy hubs $150.00
R32 gtr booster and master $120.00
R32 gtr ABS unit $100.00
GTR diff modified for rwd $300.00
R32 gtr rear cradle $40.00 (bare) needs bushes and clean up
R32 gtr rear calipers $200.00
R33 gtr twin exhaust from twin td05/6 turbo set up 4" single after diff (big power system)$550.00
XTR/subzero 62mm ext wastegate huge gate never used V bands included $800.00
R32 gtr gearbox good condition push type $500.00
Apexi air pods good condition $120.00
HKS mushroom air pods $100.00
GTR front pipe twin 2.5" stainless x something brand $150.00
R32 gtr standard rods n pistons x6 $250.00
GTST 4.1 viscous lsd good condition in $200.00
GTST ghetto 3" dump pipe, has flexi joint and some repairs worked fine $80.00
Stagea auto box (cut wiring) ran perfect $150.00
Stagea dash c/control pieces 78000ks = offers
I have more parts to add and will update pics as I can, location: South of brisbane phone 0431787453
More pics..
Edited by rb30dett
https://www.sau.com.au/forums/topic/309090-gtr-gtst-stagea-parts-clear-out/
Some reason I can't edit?
Power fc + controller suit r32/33 gtr $850.00
Stagea 5 stud hubs front & rear suit 5 stud conversion $150.00
Jaycar boost and fuel controllers wth hand controller $140.00
HKS coilovers suit 33/34 gtr perfect condition just little surface rust $950.00
R32 hicas rack $30.00
R33 hicas rack $50.00
Edited by rb30dett
More:
rb25det ser 2 from stagea so 4wd block short motor $300.00
rb25det complete head, cams valves etc vgc $600.00
GTST used turbo, needs seal kit bearings good wheels good just leaking oil past seals $120.00
GTR standard dumps $50.00
The following parts will not be removed until deposits are taken for all.
Have a Mines step 3 package on the stagea so will be selling (rb26)
HKS 2530's older style with HKS cast iron dump pipes $2200.00 vgc
Mines afm's plug in same as nismo's but these are supposed to be better $500.00
Mines ecu tuned for 2530's afm's 600cc injectors and fuel pump (runs great) $300.00
Nismo purple 600cc injectors been cleaned and flowed resently $600.00 pc
GTR 600 x 300 x 100 mm cooler looks like greddy but no markings $500.00 vgc
Will do a package deal for the lot $3500.00 300rwkw easy This is advertised locally so may sell off the forum.
Standard gtr sump & diff $300.00 vgc
R32 gtr front subframe vgc $150.00
R32 gtr steering rack vgc $120.00
R32 bare front cut $200.00
R32 gtr steering colum with key $100.00
R33 standard ecu $200.00 pc
Edited by rb30dett
Sorry for the delay guy's I work long hrs
KamikazeNinja34: Are you talking the location of the speed sensor? its front.
JnJ: South Maclean/Jimboomba
ydawak: No sorry not stagea
Front pipe & HKS pods sold
Make some offers I need the space.
Edited by rb30dett
thanks heaps paul, good to meet you..guys very easy to deal with, good prices.... highly recommend!!!
bought GTR front pipe and HKS filters :)
Edited by nissan32GTR
lol i mean that for a car thats purported to have two diffs powering its awd system, my rear diff is starting to lock up :P
So you want a rear GTR diff then? A lsd or mechanical? don't think there is a diff between ser1-3 only Vspec or non Vspec I also have a Stagea diff they are all in perfect working condition, The diffs listed are rear diffs there are pictures of both?.
Cheers
Edited by rb30dett
Standard gtr sump & diff $200.00 vgc
R32 gtr front subframe vgc $80.00
R32 gtr steering rack vgc $80.00
R32 gtr steering colum with key $80.00
Prices are neg throw me some offers
  • 7 months later...
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
    • have you rotated the car yet? if so how smooth was it?
