ryan101 Posted February 21, 2010 Share Posted February 21, 2010 As above, just wondering if it would effect anything?? It's the rubber pipe between the bov and the metal pipe that goes back into the intake?? Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/ Share on other sites More sharing options...
geraus Posted February 21, 2010 Share Posted February 21, 2010 yeh it would , your car would run funny. Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098508 Share on other sites More sharing options...
l_uk3y Posted February 21, 2010 Share Posted February 21, 2010 In theory it should create a small intake leak. Due to the fact there is no valve to stop air getting to that leak from the AFM side. Air will be measured through the AFM then have potential to go up the BOV return pipe and out the leak causing tune issues. Small leak probably wouldn't make a massive difference I wouldn't think but I'm sure it would have some effect. The larger the leak the more it will throw the tune out. Never actually tested with a leak to prove this though. Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098519 Share on other sites More sharing options...
geraus Posted February 21, 2010 Share Posted February 21, 2010 stalling... and your car could even run rich, depending on how big the hole is.. just get it fixed man, change the whole pipe from the wreckers or something Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098524 Share on other sites More sharing options...
ryan101 Posted February 21, 2010 Author Share Posted February 21, 2010 It's an easy fix, just need to replace it! The hole is bout 2-3mm, it's just after the bov Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098528 Share on other sites More sharing options...
GTScotT Posted February 21, 2010 Share Posted February 21, 2010 if its the rubber hose from the bov itself onto the return pipe just slip it off and go buy a length of the same ID hose from any auto place and replace it. simple. but dont leave it, as said it will create stuff ups on the AFM signal. Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098607 Share on other sites More sharing options...
ryan101 Posted February 21, 2010 Author Share Posted February 21, 2010 it's been like it for ages. i just didn't think it would matter! but i have a hose and it will be fixed 2moz morn! Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098610 Share on other sites More sharing options...
JonnoHR31 Posted February 21, 2010 Share Posted February 21, 2010 stalling... and your car could even run rich, depending on how big the hole is its a leak after the afm but under boost its before the turbo (bov is closed under boost), therefore it'll make it slightly leaner all the time. but unless its a huge leak it'll still be rich overall because of the standard ecu. if the leak were after the turbo it'd be leaner off boost and richer on boost Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5098911 Share on other sites More sharing options...
ryan101 Posted February 22, 2010 Author Share Posted February 22, 2010 found out when i pulled it apart that there was 3 different size rubber pipes to the metal intake pipe, what a mess! all fixed now, used a radiator hose with the right bends in it! worked fantastic Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5099929 Share on other sites More sharing options...
ryan101 Posted February 23, 2010 Author Share Posted February 23, 2010 After replaceing the pipe it's seems to recover boost after each gear! Link to comment https://www.sau.com.au/forums/topic/309091-would-a-hole-in-the-plumb-back-bov-pipe-do-anything/#findComment-5101987 Share on other sites More sharing options...
