R33 RB26 head, all covers, HKS 280 pro cams, tomei type 2 springs and buckets, tomei cam cap studs, some porting, machined and fitted rear oil drain, machined for cam clearance, $3200- SOLD (unassembled - can arrange to have it asssembled)
HKS T51r ported manifold and HKS GT wastegate
$1900 SOLD
Endless Plenum $2200 NEW SOLD
Billet Throttle body to suit $550 NEW SOLD
Hi guys,
I have bought and stored the following parts for a while now and realised that i probably wont be needing it. Bought it off the infamous BU5TER. The above head flowed 450RWKW nicely through an auto box. cam covers included. Sorry no flow test have been conducted.
Manifold has also been cermaic coated and includes a dump pipe to suit gtst. It is V-band, however HKS make a adaptor plate to use with T04 based turbos
Plenum is a work of art - just check out greenline to see the current price then add freight. Hypertune base theres off this. Also the Billet throttle body is to match this - dont ask me what diameter it is either :D b/c i have never measured it.
Prices are as above please pm any serious request - unfortunately items are in DEEP storage in the garage and a simple pic is not possible unless i get some serious interest. Items are located in syd.
Cheers
Steve
Edited by HKS26T
  • 1 month later...
  • 1 month later...
Hey mate I'm realy I terested in your gtr head for the 2500 what is included the head buckets caps studs rocker covers ?
Do u have flo charts of the head as well
  • 3 weeks later...
how much u want for the plenum
Manifold Cermaic Coated
PAID $1900 NOW $1750
Endless Plenum PAID $2200 NOW $2100
Billet Throttle body to suit PAID $550 NOW $400
Edited by HKS26T
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
