Hi,
Just selling some mats that I have lying around in the garage.
1st set is from an R32 GTR. Unfortunately I have misplaced the driver's side mat, but I was using the r33 mat which actually fitted better, although they do miss match in colour.
No rips, tears, slight fraying to the borders. $60
2nd set is for an R34, in excellent condition. The only wear is in the heel patch, which you can see in the pic. Other then that the mats look great. $150
Pick up is preferred, however will post at buyers expense.
https://www.sau.com.au/forums/topic/309120-r32-r34-car-mats/
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
