hey guys
i just replaced my clutch to a exeedy heavy duty and ive bled it all and done it properly .... (i think )
but when i take off in 1st it starts to shudder and also the start of 2nd. but then goes away ! :)
just wondering if yous can help a bit ?
my mate said it might be the fly wheel coz i didnt get it skimmed ? but i cleaned alll the stuff
off it ,so it was pretty smooth.
thanks
https://www.sau.com.au/forums/topic/309149-shuddering/
Could be the fly wasn't skimmed properly, or if its a twin plate or anything, they make noise and vibrate a bit as far as I know...
It might just need to bed in too, the vibration you're feeling might just disappear the more you drive, either way I wouldn't suggest raping it (unless you enjoy rebuilding/replacing gearboxes...)
Speaking of which was the gearbox/diff in good condition before you replaced the clutch?
https://www.sau.com.au/forums/topic/309149-shuddering/#findComment-5099001
    • I’ve been considering one of these screens too, but I've heard mixed reviews about the software responsiveness. Some say it's great, while others mention lag issues. Before pulling the trigger, I'd check out a few recent user experiences to see if the latest models have improved.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
