hey guys ive recently had more issues with my 30 just wondering if someone could help me out... recently the motor after an hour or so highway drive started to knock, I just can't understand why...initially i thought it was the hydraulic lifters or something as it sounded like it was coming from the head,it was fairly similar to the sound I heard when i first done the start up after a while of warming up it had gone away. I can't understand how it maybe a bottom end knock, as everything is acl race, forged pistons, shot peined rods, n1 oil pump etc motor was fully balanced and had a run in tune. I only had a standard rb20det turbo on there as I had just finished running it in and only just done the oil change. I cant understand what it may be the car did not over heat on the long trip or lose any power. Thinking back i do remember when i was bringing the car back from the tune at traffic lights the oil pressure droped dangerously low and when i gave it a few revs it went back up again so i kept the revs up on the drive back home, but since then it has never happened again (this would have been in the first 50km or so of fresh build).
I do not know what it can be, please help?!?!? :thumbsup: The oil that i'm using is Penrite HPR 10
Few days ago I done a compression test and got between 110-120 across all the cylinders, I thought it may be as the motor is still fairly fresh or maybe the pistons I used were lower compression/head gasket maybe?
Anyone have any ideas? I'm just hoping I don't have to pull the motor out again lol
https://www.sau.com.au/forums/topic/309178-someone-please-help/
  • 8 months later...
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
