UPDATED: 21/02/10
So i decide to post up my car here as well, the main build thread will still be on NS however I will update this thread from time to time since sometime in the future ill be attending SAU track days.
Basics:
1995
Manual
A fair few kms.
Burgundy paint, some parts faded.
Engine:
Random ass stainless steel manifold.
3" turbo back, including cat and a huge genie turbo muffler.
pod filter(needs a box)
new water pump (installed by ADM)
new midnightmods braided turbo water line. (installed by ADM)
Wheels/Tyres:
R33 stockies up front, with 205/55/16
ford stockies(black) with goodyear eagle f1s, 215/45/17.
Brakes/Suspension:
QFM HPX pads front/rears.
castrol super dot 4 (couldn't afford motul tongue.gif)
Bodywork:
Luxury front lip
ADM spoiler
Sunroof
Debadged.
Interior:
old clarion headunit
two 6x9" clarion speakers in the rear(hectic bass bro)
two unknown speakers in the front.
Things I've done:
changed the oil and filter.(jan)
changed the diff oil, require the exhaust to be dropped..(jan)
painted front lip gloss black..(jan)
satin black wipers(jan)
removed the door beep with keys still in the car. .(jan)
installed new pads, changed brake fluid(feb)
changed clutch fluid(feb)
changed gearbox oil(feb)
painted chrome exhaust tips black(feb)
rewired indicators(feb)
removed fog lights(feb)
Things I'm doing:
nothing
Plans:
Heat wrap, (will get stock manifold instead with new OEM gaskets later on).
Ducting.
Wheel alignment.
Muffler.
Spray roof.
investigate noise.
suspension.
light weight rims.
strip interior.
Parts for time-attack( a long way off)
I bought the car with the intent to take it to the track yet track days aint cheap, might be a while before i go down but im sure it ll be worth the wait. However it is a daily, it will still need to be somewhat practical.
Pics:
below:
https://www.sau.com.au/forums/topic/309190-s14-dailytrack-car/
The whole idea is to put up a huge first post, then add others as you do things
linking to ns.com is useless
If you'd like to have a thread here like everyone else, please use the same format. Otherwise the thread will be closed. SAU does things one way and ns.com does things their way. Over here all the info needs to be on this forum so if it's too time consuming to update sau and ns I'd suggest you choose one and do a good job at that one
:rofl:
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
