^ factory breather joined, factory PCV still connected.
With the above setup, the catch can will only "catch/breathe" when there's positive pressure in the plenum. On VAC/idle/off boost the plenum will pull nearly all of oil vapours.
Yep! Sounds good to me. :thumbsup:
  • 3 weeks later...
Hey SAU Members.
The attached PDF file is a brief DIY guide to the installation of an D1 Spec Oil Catch Can, as sold by Just Jap.
Hope it helps.
Hey mate! I followed your install on my S2 r33 GTST and I've had the catch can on there about 2 weeks now and what I don't understand is why my catch can is still empty?? Like literally nothing not one spec of oil? And I give it the berries every time I take it out
This worries me haha
  • 5 years later...
Hey All,
Know this is an old thread but thought i would add my own experiences to this as I am in the process of installing mine and found some products that may make this simpler. I've gone with a catch can with two inputs, one outlet. The inputs for the catch can are already AN-10 so no adapters needed and the output on the can is AN-12 so just need a simple AN-12 to AN-10 reducer.
I am in the process of purchasing the following:
1x Raceworks Catch Can - 3 Litre BLACK ALY-063BK
3 Metres x Raceworks - 400 Series Push Lok Rubber Hose - AN-10
3 x Raceworks - 400 Series Push Lok Hose Ends 90 Degree AN-10 (2 for the rocker covers, one for the top of the catch can)
2 x Raceworks - 400 Series Push Lok Hose Ends - Straight AN-10 (for the catch can)
2 x Raceworks Male Flare Union AN-10  - RWF-815-10BK (for the inlet ports of the catch can)
1 x Raceworks AN-12 to AN-10 reducer (tbc if male to male (rwf-815-12-10bk) or female to male (rwf-950-12-10bk)) (for the outlet port of the catch can)
1 x Franklin Engineering 10AN Rocker Cover Fittings for RB25 (2 in the pack with an installer)
Aim is to remove the two existing Rocker Cover barbs using some pliers (you tube has a guide on this) replace them with the new AN-10 adapters from Franklin engineering.
Will then add the two Raceworks 90 degree Push Lok fittings to the rocker cover and then connect those to the two inlet ports on the catch can. Will then run the 90 degree push lok fitting on the outlet port and run that to the stock fitting on the PCV.
Will post my experiences and pictures once complete
Toby
Edited by Tobz
Clarify
  • Like 1
Can confirm the top of the can is a male AN-12 fitting so ordered the rwf-950-12-10bk
Parts should all arrive in the next week or two so hopefully can then comment on the install process soon!
So parts have arrived. Turns out the top is an AN10 already so no need for any adaptors for the top
Here is a picture of the can with the top 90 degree connector at the top, front male to male connectors and the straight hose fittings.
On the side of the push in fittings for the engine and the 90 degree fittings for that. Also came with a little 3d printed cover to help knock the push fittings in
Any update?
On 19/09/2019 at 9:40 AM, Smitty2u said:
Any update?
Yep! I think I went to big with the catch can and can't find anywhere to mount it. Trying to decide whether to get a smaller can or relocate the battery.... But the concept is sound and all the parts fit, so if you went with the 1l can it wouldn't be an issue
Its a serious looking unit - keep it and relocate the battery to the boot...
  • Like 1
Have taken your advice and will relocate! Im going to the wreckers on the weekend to pick up an R33 rear battery tray so it can look all nice and stock :)
    • Rear doors central locking wiring removed and cleaned. See the first 8sec video of when it’s filled with river silt. its a snip of what I’m up against. front and rear doors complete now. Maybe another day removing carpet and bits and pieces. Then the re assembly begins. 🤙 att.DqweJqhY5MZiZYQDVMhn3LtvdD1RBZ7TBG4f2s7W1zM.mp4 att.lFuN22MZEowqCbFAXoDw009r2gHL76ChMVfxMfBX-uk.mp4
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
