I've read that the m35's cruise will only go up to 110kmh. Just wondering if there's any way around this to allow slightly higher speeds... Without complete replacement.
One thought I had is if the cruise is a stand alone unit which accepts a speed signal from the ecu or box then the speed signal could be intercepted and altered i.e. Jaycar gearbox sender correction unit for electronic speed sender units. They work by altering the number of pulses so in effect could tell the cruise unit that the car is going slower so higher real speeds could be set.
Unless of course the cruise is fully integrated in the ecu which wouldn't surprise me.
https://www.sau.com.au/forums/topic/309292-m35-cruise-control/
