I also have a compleate working engine from my EP82 1990 starlet GT, body has suffered a rear end accident but has some salvageable parts here is a list of mods
Evo 7 FMIC
garret ball baring turbo from a nissan silvia
Hks bov
Hks Pod
Hks Strengthend and adjustable actuator
Aftermarket sparkplug leads
HKS fuel cut defender
A'PEXi AFC soon to go on the upgraded SAFC II
manual boost control
Whiteline Anti-Lift, Front sway bar, Rear Adjustable sway bar
Standard front strutt brace
Cusco tube style rear strutt brace
Camber Bolts
Aftermarket Spring n Shocks (Jap spec, un-know)
5Zigen catback exhaust and aftermarket dump pipe
Dish steering wheel
A'PEXi Boost gauge
A'PEXi turbo timer
Fire Exstinguisher (Deca ready)
Sitting on Black Wantanabe 14's wheels
H4 10000K Hid
RDA slotted rotor
ABS standard.
there are also the interior parts, hood and front bar that are still good
Item Condition: good
Price and price conditions: $2000 ono for the lot (entire wreck) i wish to use this as part payment in a trade perhaps
Extra Info: selling because i was rear ended on westerport hwy . would prefer car taken as a whole
Contact Details: call me on 0412 054 982
Delivery & Conditions of Delivery: pick up only (or as arranged with individual)
NOTE: THAT CAR DOES STILL DRIVE AND ENGINE AND EXHAUST ARE ALL UNDAMAGED, BUT HAS BEEN DE REGISTERED BY MYSELF.
https://www.sau.com.au/forums/topic/309333-need-a-new-car/#findComment-5102827
sale fell through, cmon guys this car has a great set up, suit engine swap into a paseo or other small toyota, car makes around 127 fwkw, running perfectly, not listed as write off by vicroads.
$2000 ono or swwaps for another car, possibly plus cash your way.
https://www.sau.com.au/forums/topic/309333-need-a-new-car/#findComment-5115791
