I am getting my hands on one of the PWR cross flow radiators with a built in oil cooler. PWR have given me the option of -10 or -12 fittings on the oil cooler. I went with -12, but can get this changed for -10 before they build it.
I am trying to get my hands on an oil filter sandwhich block, with built in thermostat, that I can run the lines to.
I am looking at this GReddy oil block but it has a heap of options on fittings http://www.rhdjapan.com/trust-0-c-oil-bloc...60mm-51270#tab3
Can someone in the know please give me some guidance on which oil block variant I need?
Car is an R32 GTR
https://www.sau.com.au/forums/topic/309352-fitting-madness-dash1012-unfm20/
My Greddy Oil filter relocation and cooler runs -10 lines.
You will find that -12 fittings will be ALOT more expensive than -10. Also, you really don't need that much flow potential... -12 is quiet a large fitting.
I'd look at a greddy oil filter plate with the thermostat if it's a street car.
Hope it helps,
Justin
Cheers guys - yes was thinking -12 was going to be too big for my purposes. Getting them to change to -10
Car is being set up mainly for tarmac rally and some track days, but is still currently registered so thermostat one will suit both.
UAS have everything I need so just passing the headache off to them!
GET -12 and if you need to get a reducer. your filter block needs to be 3/4 unf. the differance in price from 10 to 12 is f**k all. buget around 30-40 for a 90 degree swivel braid fose end. the russel fittings from rocket ind.. are alot cheaper but still good.
