"rev It Up" At Enigma Bar Fri Feb 26th- Calling All Car Enthusiasts
"Rev it Up" at Enigma Bar, Hindley St, this Friday Feb 26th, 7:30pm till late.
Band "Legless" releasing their new dvd, comedian "Lehmo", bands, DJ;s, a panel of car identities discussing topics such as hoon laws in SA, car stereos, car sex, why people spend money on their cars and MORE.
Come for a wicked night out.
$20 tickets at the door, or available from
http://tix.adelaidefringe.com.au/ticketing...4a-edb04e78b203
Event was to be at HQ, now changed to Enigma Bar.
BE THERE........
comedian "Lehmo"
these 2 words are an oxy-moron.
you must have been scraping the bottom of the barrell/or lost a bet to have the worlds most un-funny person be your comedian for the night! stupid un-funny homo, always squinting, i would consider going just to heckle him.
couldnt agree more
hate try hard mc 'comedians'
if only someone would shoot that fitzy idiot, the air would smell so much sweeter
-D
lehmo funny,,,,, yeah looking , annoying yes
HQ hmmmmm NO Thanks !!
first post no less = fail
is that "Flic" from SAU who posted this up ? if so hello :)
couldnt agree more
-D
if you guys agree that a mentally retarded mid 40's woman, a bald man who isnt good at prank phone calls, and a fat whinging guy from norlunga downs should also be infront of the firing squad with an excuse for an f-grade celebrity (fitzy), we could be the bestest e-buddies ever!
PS, while im in the mood, i am going to throw into the rumour-mill that when lehmo was doing SAFM morning radio with his co-host Milly, he "tapped" that.
PPS, pass that on
couldnt agree more
-D
PPS, pass that on
the woman would be amber petty right? her and fitzy deserve to be blasted into space on a 2 man prison vessel... in space no-one can hear fitzy scream
-D
Im interested to what is going to come out of this discussion. "Have your say" kinda points to the fact that people will be talking about issues that are affecting the import/car enthusiast community at present, but are these "car identities" going to rally for us and get our points across to the people who matter, or is it just a pointless bitch about what the government wont do for us? If its the latter, I can just stay on SAU with SAFM playing, looking at suicidegirls.com.
yeah +1, thats a good point damo!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
