"rev It Up" At Enigma Bar Fri Feb 26th- Calling All Car Enthusiasts
"Rev it Up" at Enigma Bar, Hindley St, this Friday Feb 26th, 7:30pm till late.
Band "Legless" releasing their new dvd, comedian "Lehmo", bands, DJ;s, a panel of car identities discussing topics such as hoon laws in SA, car stereos, car sex, why people spend money on their cars and MORE.
Come for a wicked night out.
$20 tickets at the door, or available from
http://tix.adelaidefringe.com.au/ticketing...4a-edb04e78b203
Event was to be at HQ, now changed to Enigma Bar.
BE THERE........
comedian "Lehmo"
these 2 words are an oxy-moron.
you must have been scraping the bottom of the barrell/or lost a bet to have the worlds most un-funny person be your comedian for the night! stupid un-funny homo, always squinting, i would consider going just to heckle him.
couldnt agree more
hate try hard mc 'comedians'
if only someone would shoot that fitzy idiot, the air would smell so much sweeter
-D
lehmo funny,,,,, yeah looking , annoying yes
HQ hmmmmm NO Thanks !!
first post no less = fail
is that "Flic" from SAU who posted this up ? if so hello :)
couldnt agree more
-D
if you guys agree that a mentally retarded mid 40's woman, a bald man who isnt good at prank phone calls, and a fat whinging guy from norlunga downs should also be infront of the firing squad with an excuse for an f-grade celebrity (fitzy), we could be the bestest e-buddies ever!
PS, while im in the mood, i am going to throw into the rumour-mill that when lehmo was doing SAFM morning radio with his co-host Milly, he "tapped" that.
PPS, pass that on
couldnt agree more
-D
PPS, pass that on
the woman would be amber petty right? her and fitzy deserve to be blasted into space on a 2 man prison vessel... in space no-one can hear fitzy scream
-D
Im interested to what is going to come out of this discussion. "Have your say" kinda points to the fact that people will be talking about issues that are affecting the import/car enthusiast community at present, but are these "car identities" going to rally for us and get our points across to the people who matter, or is it just a pointless bitch about what the government wont do for us? If its the latter, I can just stay on SAU with SAFM playing, looking at suicidegirls.com.
yeah +1, thats a good point damo!
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
    • Plan B? Get someone to machine up a metal bush/collar/whatever it needs to be to replace the rubber? I haven't had a close look at that part recently to have a proper feel for whether that's possible. But it might be easy.
    • I do not want to install a short shifter and the only other stock throw shifter I have seen is the Nismo "Rigid shifter" for $290 So plan A is to fill it with sikaflex to stiffen it up and hope for the best
